20 Most Recent Amana ALE443RAW Gas Dryer Questions & Answers
HOW DO I REPLACE BELT ON AMANA DRYER?
Hi allenstyappl
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Note: This method works for most front loading machines.
If you have to check/replace/repair your drum motor,drum seals,belt,rollers, etc.
If replacing drum seals be sure to use a good grade of weather proof cement to hold the seal/s in place, some seals are furnished with the cement to glue it in place.
Remove the electrical console that holds the timer switch,start switch, etc. from the top of the dryer if necessary. Be real careful not to knock any of the wires off of the timer switch or other electrical connections.
Remove the lint filter and the two screws that hold the filter housing to the top of the dryer lid.
Then remove the top of the dryer by inserting a screwdriver between the top and frame on each side of the dryer to pop the lid up from the retaining clips.
Note: Some of the tops tilt backwards on a type of hinge and do not have to be removed completly.
Remove the front of the machine by disconnecting the door switch and removing the two screws located on either side of the dryer frame.
Move the door and front of machine forward to remove.
This will expose the belt,idler bracket and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
Note:The way the belt goes back on is, as the belt comes off the drum has to be doubled (pushed together to form a loop) and goes under the idler pulley then to the motor pulley.
Here is a link to see a picture of your belt routing in case the belt is broken when you open your dryer:
http://www.expertappliance.com/dryerbeltconfiguration.html
While you have the drum out, I would recommend that you remove and lubricate the drum rollers.
And also clean the shafts of the rollers as they will collect hair,dust,etc and cause problems and then lubricate the shafts and rollers with a good grade of machine oil like 3 in One oil or a vasoline type of lubricant. This will save you a problem later with the rollers getting dry and making a squeeling noise, also check your drum rollers for flat spots, if they have flat spots on them this will cause a thumping type noise.
You will need to replace the drum rollers if they have flat spots on them.
Please take time to rate me thumbs up
9/9/2011 8:39:12 PM • Amana ALE443RAW... • Answered on Sep 09, 2011
Electric dryer felt ring around
replace the felt ring
4/14/2011 12:30:32 AM • Amana ALE443RAW... • Answered on Apr 14, 2011
The flame comes on the
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
1/28/2011 10:56:23 PM • Amana ALE443RAW... • Answered on Jan 28, 2011
Timer does not turn and
heatman101
1/24/2011 4:44:18 AM • Amana ALE443RAW... • Answered on Jan 24, 2011
The motore will run, but it is not spinning. The
Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt.
Here is a link to the belt.
1/6/2011 11:38:50 PM • Amana ALE443RAW... • Answered on Jan 06, 2011
Dryer will not heat
Hello. When the dryer won't heat up, begin by checking the vent pipe and removing any lint in the pipe and in the rear of the machine. Next, clean the area that has the burner and the thermocouple. Finally, with it pulled out so you can see what is happening, turn it on and see if it lights. If it does not, replace the thermocouple. Joe
4 thumbs up please. ty
11/4/2010 4:48:36 PM • Amana ALE443RAW... • Answered on Nov 04, 2010
2answers
Amana
Under front of dryer, there are two 5/16" machine screws which hold the kick plate on. Remove these for access.
8/10/2010 2:19:46 PM • Amana ALE443RAW... • Answered on Aug 10, 2010
Dryer not heating
clean the entire venting system and try it again
5/22/2010 2:42:34 PM • Amana ALE443RAW... • Answered on May 22, 2010
Loud bumping sound from dryer.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial " This should give me an ida of what to look for once I open er up " -
5/12/2010 4:26:54 AM • Amana ALE443RAW... • Answered on May 12, 2010
2answers
How to clean internal lint buildup
Buy a lint brush at Walmart or other retail store. It's a long plastic bristle brush that will allow you to reach down in to the cavity of the blower intake. I always use a vacuum hose to **** up what it pulls up so it won't fall back down in.
11/18/2009 4:39:51 PM • Amana ALE443RAW... • Answered on Nov 18, 2009
TRYING TO REMOVE FRONT
The sock is binding in the blower wheel which in turn stops the motor.
Unplug the dryer and turn off the gas supply. Look down at the very bottom of the front panel to find and remove the 2/3 screws across the bottom. Pull the bottom of the front panel out then down to release the clips holding it to the top cover. This will give to access to the other parts to retrieve your sock.
10/31/2009 9:07:47 PM • Amana ALE443RAW... • Answered on Oct 31, 2009
I was told my problem is the cutout, where can i
The thermal cutout(fuse) is normally located either near the heater (electric) or near burner (gas)...will either be flat and round with 2 terminals sticking out(wires) or flat and rectangular with 2 terminals. 6256b6c.jpg af7bf92.jpg Here are 2 typical thermal fuses which maybe what your looking for dependent on your dryer. Hope this helps! Mike
7/10/2009 7:50:06 PM • Amana ALE443RAW... • Answered on Jul 10, 2009
Amana electric dryer won't heat up
It can really only be two things. The element or wiring to it has failed or The Thermal fuse has been overheated and cut off power. Both can be checked with a Digital Multimeter. If your Amana dryer is not heating, it likely has either a defective heating element, thermal fuse, high-limit thermostat, or cycling thermostat. If you have a gas dryer, it is likely not heating because of a defective gas valve solenoid. Feb 2, 2022
Amana Dryer Not Heating? Here's What to Do - Fred's Appliance
All question need full make and model to fully assist you. https://www.google.com/search?q=Amana+%28model%29+dryer+parts ..
10/21/2023 11:51:12 PM • Amana Dryers • Answered on Oct 21, 2023
MY AMANA DRYER IS HEATING, BUT THE DRUM IS NOT TURNING AND THE BELT IS NOT BROKEN
see pics and check for bad bearings and or bad motor switch, loose belt or belt not conected to motor tensioner belt replace tensioner belt-undefined-undefined-0.jpg belt tensionerdryer3-undefined-undefined-1.jpg belt tensionerdryer3-undefined-undefined-2.jpg beltswitcht-undefined-undefined-3.jpg bearings dryer old newoldbearing2-undefined-undefined-4.jpg beltswitch-dryer-lint-filter-in-door7-undefined-undefined-5_0.jpg
7/22/2023 10:13:39 AM • Amana Dryers • Answered on Jul 22, 2023
Amana NED7200TW dryer. Which brands/models of pedestals are compatible with it please?
Question edited for clarity.
10" Pedestal for Front Load Washer and Dryer
Amana https://www.amana.com > ... > Laundry Organizers Amana 10" Pedestal for Front Load Washer and Dryer - White (XHP1000XW). ... Raises Your Washer and Dryer to a More Comfortable Height for Loading and ... US$278.00 · ‎In stock More here https://www.google.com/search?q=Amana+NED7200TW+dryer+%22pedestal%22 ..
7/6/2023 4:36:31 PM • Amana Dryers • Answered on Jul 06, 2023
Amana dryer model ngd7200tw smells like gas when it runs and it's not heating up
That is dangerous. Call for service, the law says only registered gas technicians can work on gas appliances. Turn the gas off at the rear. There is enough gas in a dryer leak to blow your windows out on that floor. The igniter or thermocouple is faulty.
7/6/2023 4:14:50 PM • Amana Dryers • Answered on Jul 06, 2023
Amana NED7200TW 27 Inch Electric Dryer. On model number YNED7200TW it is turning on but not running.
Question edited for a lot more clarity. Question moved to maker category. The Belt https://www.google.com/search?q=Amana+YNED7200TW+replacement+belt Videos
4/17/2023 8:09:26 PM • Amana Dryers • Answered on Apr 17, 2023
Amana tandem dryer Model# NED7300WW1 temperature button not working
The buttons and the control panel need to be repaired or retrofitted or be replaced.
3/26/2023 8:28:28 AM • Amana Dryers • Answered on Mar 26, 2023
Amana NFW7200TW Front Load Washer. Is there a trick to changing the baffle out as far as accessing screw?
Question edited for clarity.No, you normally do a full tear down and split the outer drum to get to the screw on the inner drum. You could undo it with grips from inside and use a magnet taped to a coat hanger to collect the screw from between the gap.
2/26/2023 2:02:28 AM • Amana Dryers • Answered on Feb 26, 2023
Amana ALE443RAW Gas Dryer Logo
17 questions posted
Top Amana Dryers Experts
Kolbrun...
Virgil Watts
Are you an Amana Dryer Expert? Answer questions, earn points and help others
View Most Popular
Amana Dryers
  • Amana Dryers
Most Popular Question
replace belt amana dryer
  • Dryers
