20 Most Recent Texas Instruments TI-82 Calculator Questions & Answers
Hi
The TI82 is a bit old Technology and if you did not use for a few years the screen is dead its a common problem with this model and the TI83
sorry for not been a big help
Texas... | Answered on Feb 09, 2019
5/3 cannot be represented exactly. Break it up into two parts, (-8)^5 then take the cube root. Be aware that their are three roots.
Texas... | Answered on Apr 06, 2017
http://www.wikihow.com/Calculate-the-Product%E2%80%93moment-Correlation-Coefficient
Texas... | Answered on Mar 17, 2015
The calculator has three display formats for results: Normal, Scientific, and Engineering. It is possible that your calculator is configured to display results in Scientific Format.
Press the MODE button. On the first line, highlight Normal. After that you can use the Down Arrow to move cursor to the second line and highlight FLOAT.
Texas... | Answered on Feb 21, 2015
There is no reset button. Just clear the memory.
Texas... | Answered on Jul 15, 2014
135-72i
Texas... | Answered on Jun 12, 2014
Press 8 . 2 3 2nd [EE] (-) 6
Texas... | Answered on Jun 01, 2014
weak battery, or loosen display.....
change battery.... if doesn't help,. open device and check screews that are holding display, if it's loosen, tight it up
Texas... | Answered on Apr 25, 2014
What type of plot? Try turning off the stat plot features.
Texas... | Answered on Dec 03, 2013
Turn the calculator on, press and hold the 2nd button, then press the up-arrow button to increase the contrast or the down-arrow button to decrease the contrast. If you go too far, release both buttons, press and hold the 2nd button, and press the appropriate arrow button.
Texas... | Answered on Nov 28, 2013
To access the inverse cosine function, press 2nd COS.
Texas... | Answered on Oct 13, 2013
There isn't one. There are, however, several buttons that bring up various sub-catalogs, such as MATH, MATRIX, PRGM, STAT, and VARS.
Texas... | Answered on Oct 09, 2013
I am not sure I understand but if it the same problem as in your other posted question, here is what I wrote.
Are the data in L1 and l2 in any way related? If they are (being x-values and y-values of some data set) then you need to do regression analysis (2-var stats)
If they are not related (connected) you can calculate the mean of each group separately.
Do 1-var stat by specifying the L1 list first (may be the default), get your average of the values in L1. Then you can do 1-var stat on the data in L2 by specifying the list L2 on the command line.
1-var L2 ENTER
Note: What I am describing here is valid for the TI 83 Plus/TI84 Plus, but I suspect the steps are similar to the TI 82.
Texas... | Answered on Oct 08, 2013
Texas Instruments TI-82 Calculator Logo
110 questions posted
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Steve Allison
Steve Allison
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Texas Instruments Office Equipment & Supplies
Most Popular Question
screen fade return
  • Office Equipment & Supplies
