20 Most Recent Walkera Devo RX701 2.4Ghz 7ch Receiver Questions & Answers
It's very simple read this manual from here https://arducopter.googlecode.com/files/PPM%20Encoder%203DR%20Manual%20v2.3.16.pdf.
Walkera Devo... | Answered on Jan 29, 2015
thank you very much, i like your article
and i have the same problem
RC airplane
Freewing RC airplane official site Flightline Official site Freewing model...
Walkera Toys | Answered on Jan 23, 2018
What type of batteries are in it now?
Walkera Toys | Answered on Aug 15, 2016
http://www.rc-king.ch/Downloads/Diagramms/Master.pdf
Walkera Toys | Answered on May 03, 2015
The walkera Lama has a bad gear setup,there are two tiny screws on the top
gear which powers your bottom blades one on each side of the outer shaft
if these two screws were not properly tighened at the factory or you ran yourLama
400 into the ground even if it was at a slow rotation when the bottom impacts
the ground the bolts shear off the outer shaft and you no longer have 100%
power to those blades,if your helicopter spins clockwise and you tried every
thing,this is the problem,replacement is required or you can tear it all down
and drill and tap two new holes with new screws,these are machine screws
and are less than 4/40 which is very small.To check hold top gear with two
fingers left and right side of gear and turn the bottom blades only,if the blades
turn your shaft to gear screws are sheared off
good luck
SK Florida
Walkera Toys | Answered on Sep 30, 2011
I'm providing you a link below for the motor which is available for 19$ online suitable for your heli.
http://www.hobby-wing.com/hm-68b-z-38.html
Walkera Toys | Answered on Mar 27, 2011
sir jeremydylan2
you have a problem with your rear rotor assembly.
if your rear rotor shaft is broken or the gear is the copter will spin around and around.
or, if these parts are not broken then your trim needs adjustment or, you need to learn to fly and control the rear tail rotor so it does not spin around. Thats your answer. thundermounts@gustywinds.com
Walkera Toys | Answered on Mar 16, 2011
Spare parts are available for the Walkera line of copters, just go to the web site below to check on the availability of parts for your model. You will need a small set of jewelers screwdrivers for most repairs and a good level of mechanical skill
http://www.walkerasite.com/
Walkera Toys | Answered on Feb 27, 2011
When the throttle starts failing this way it is a sign of either a failing contact or batteries. But since you said the batteries are fully charged then we can eliminate the batteries out of the equation.
The throttle contact does not make as much contact as it is supposed to and therefore starts up the rotors and then does not continue giving as much power as it is supposed to.
There could be a power flow breakage or a partial contact somewhere hence the initial startup and the stoppage.
Hope this solution has been helpful?
Walkera Toys | Answered on Dec 27, 2010
Try this link
http://www.heliguy.com/i/Walkera%20%2060C%20Manual.pdf
It's over 5 meg to download.
If is not the correct model then search here for the correct model #
http://www.heliguy.com/Forum/RC-Helicopter-Manuals.html
I’m happy to assist further over the phone at https://www.6ya.com/expert/dan_91204789c5bd4b93
Walkera Toys | Answered on Sep 10, 2009
Hello, Cliff -
Apparently the Luvabella dolls are manufactured and sold by Spin Master. This is the link to the Spin Master Contact Us page:
http://www.spinmaster.com/contact-us.php?userLoc=us
If you click or tap on the Customer Support "button", you can fill in a form which can be sent as an email. Or, if you click or tap on the Customer Service link, with the telephone receiver icon, you can find the Customer Care telephone number to call. Or, the Contact link, will display links for countries worldwide.
I did not see your problem described in the instructions for the Luvabella doll,
https://spinmastersupport.helpshift.com/a/luvabella/?p=web&s=getting-started&f=instructions&l=en
therefore, I think you need to contact Spin Master directly and ask about the problem you are experiencing.
Best wishes.
Toys | Answered 3 days ago
Walkera Devo RX701 2.4Ghz 7ch Receiver Logo
2 questions posted
Top Walkera Toys Experts
Michael Galve
Michael Galve
Marvin
Marvin
aldwin weng
aldwin weng
Are you a Walkera Toy Expert? Answer questions, earn points and help others
View Most Popular
Walkera Toys
  • Walkera Toys
Most Popular Question
yet ever get response from one things
  • Toys
