20 Most Recent
Avery DesignPro Deluxe CD-ROM Label-Printing Software (50072782052398) Questions & Answers
My software will not download
My friend i will recommend you to download software with the help of download accelarator so that is will download any software even there is net problem. Best Of Luck.
You can download Download accelerator from http://download.cnet.com/Download-Accelerator-Plus/3000-2071_4-10037157.html
I am trying to make
I had the same problem. The solution I came up with was to use Microsoft Publisher to print the labels. First I drew a circle about the size of the cd and another inside it for the centre. I printed it out on a plain sheet of A4 paper and measured held it over the label to see how they matched up. I dragged the circles in publisher using trial and error until the circles came out in the same place as the circles of the labels. Then I designed the label inside the circle using publisher and when I printed it on the label it came out in the circle.
If you don't have publisher just check the paper shown in your print dialog and make sure you have changed it to the label type you're using rather than A4 Plain which is the standard.
I'm trying to print the cd label on the label
Some CD label software allow you to adjust the "overprint" by resizing the image you are printing. If your software doesn't allow you to size your image larger than the label (so it overlaps) try a different program. Look for a setting that allows it to over print. It's not an exact science...you just have to try to make the adjustments you need. There are also different CD/DVD label sheet types where the labels are setup on the sheet differently. maybe a different setup may work better. However, usually Avery is pretty good.
Paxar 636 diagnostic test 2 error
paxar 636 diagnostic test 2. i've encounter this problem last 2004. the diagnostic test stops at diagnostic 2. what we did is that we've checked the mother board and the printhead board. basically those boards are the main problem when you encounter that error (diagnostic test 2 error ). what we did is that we changed the mother board as well as the printhead board.
Avery Ink Jet Magnetic Sheets - 3270
It worked fine for us on an Epson. We printed about 40 sheets fed one at a time. Do not stack the sheets in the feed hopper, they stick together because of the magnetism.
There is no template because the material is not die cut. It is just full 8.5x11" sheet size.
Avery DesignPro Error while initialising
Reinstalling and restarting won't solve the problem. For some reason Avery design pro limited attaches it self to windows user account. You can create another windows user account and run the program and it will work. When you start the program in the new windows user account it will ask you for your name "Author Name".
MAILMERGE USING "WORD" & AVERY LABELS
If you have Microsoft Word, you can open a template of the label you're using (which is free from Avery if it isn't already in Word) and make that document into a mail merge document.
