20 Most Recent Copystar CS-1810 Copier Questions & Answers
Add toner
Copystar CS-1810... | Answered on Mar 14, 2019
There is still a jam inside the copier
A jam still exists inside of the copier
Clean your main charger
and Exploser lamp
Copystar CS-1810... | Answered on May 05, 2014
I'm sorry, Copystar is not a brand I am familiar with.
Be blessed.
Copystar CS-1810... | Answered on Apr 29, 2014
that means your laser unit is not spinning up to speed. sometimes, you can fix by pulling laser unit and removing the polygon lens/mirror, then putting a small drop of lube on shaft and re-assembling. other times, you have to replace laser unit. thats quite expensive.
hth,
razors
Copystar CS-1810... | Answered on Jun 13, 2012
yes the drum will need to be replaced the cleaning blade is not cleaning the drum
Copystar CS-1810... | Answered on May 19, 2012
this might result from feed rollers not picking the paper. remove cassette and clean the paper feed rollers
Copystar CS-1810... | Answered on Aug 18, 2011
You can download the manual here:
http://usa.copystar.com/americas/jsp/Kyocera/resource_details.jsp?pid=5179&rid=2076
E70 means that the last original from the feeder was not copied and should be placed on the glass and copying resumed.
Please come back and rate the solution if helped or post a comment for further assistance.
Thank you for using FixYa, the community-based help site :)
Copystar CS-1810... | Answered on Jul 26, 2011
To reset you device: You need to run sim U163 to reset fixing heater problems.Press and hold stop, start, and left exposure key in that order. Release andpress stop again. Use zoom keys to enter 163, press start. Exit the mode byentering 001 and start, or power off/on. Hope this will help you. Good Luck.
Copystar CS-1810... | Answered on Jul 23, 2011
Here is a link to get the instruction manual you will need to change the default setting for F19 I believe which should be in chapter 6. Should be on pages 6-4 and 6-7.
http://usa.kyoceramita.com/americas/jsp/Kyocera/download_center.jsp?pid=5053&pcat=10564&rcid=10009&rscid=10028#bottom
Copystar CS-1810... | Answered on Jul 14, 2011
If it is a Kyocera toner than that is the problem. The key to turn the toner is different for the Kyocera toner cart. It will fit and appear to work but won't. Also turn the unit off and unplug for 15 sec. will reset and perform boot up procedures might help.
check the charging corona unit.it might be dirty of not aligned properly.clean it with alcohol
Copystar CS-1810... | Answered on May 25, 2011
Broken fixing heater wire
? It takes 15 s or more for the fixing temperature to reach 50°C/122°F after the power is turned on or the safety switch is turned off and on.
Fixing unit thermistor installed incorrectly.
Check and reinstall if necessary.
? It takes 10 s or more for the fixing temperature to reach 100°C/212°F from 50°C/122°F.
? It takes 24 s or more for the fixing temperature to reach the secondary stabilization fixing temperature from the primary stabilization fixing temperature.
Fixing unit thermostat triggered.
Check for continuity. If none, replace the fixing unit thermostat.
Copystar CS-1810... | Answered on May 18, 2011
AP error message means...to Add Toner.
Copystar CS-1810... | Answered on Apr 10, 2011
Copystar CS-1810 Copier Logo
80 questions posted
Top Copystar Office Equipment & Supplies Experts
Tammie Duggan
Tammie Duggan
Adorjani Laszlo
polytek
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Copystar Office Equipment & Supplies
Most Popular Question
getting reading e70
  • Office Equipment & Supplies
