20 Most Recent
Coleman Propane Stove 5423E750G Grill Questions & Answers
My Coleman classic propane stove NO gas getting to the burner
Are you stating that the igniter will not work. Is the igniter failing to produce an ark? Are you stating that the burners fail to be supplied with gas. With both the bottle's valve open and the stove turned on. Make sure the propane bottle has gas first. Is the bottle heavy and do you feel liquid moving around inside like water if you move the bottle around in the air? Check the valve. You can not open the valve quickly. On these 20lb. bottles. You must turn the knob very slowly or the bottle will slug. You will need to shut the gas flow off, wait a minute for it to equalize and try it again. Open the gas flow slowly(at the bottle). Now try to light the stove. If the stove is still not lighting you can try another bottle but more than likely the regulator has gone bad and will need to be replaced.
How do I remove the knobs?
I am guessing its a gas Coleman? If one of the knobs is hard to turn, I would suggest that the gascock it operates is seizing up. The gascock will need to be stripped, cleaned and regreased.
