20 Most Recent
Conair HUM1200Y (10 Channels) 2-Way Radio Questions & Answers
Icom IC706mk2g Transceiver does not transmit in SSB (Single Side Band) (USB & LSB)
First, make sure that the microphone is properly connected to the transceiver. Check all the connections and ensure that there are no loose cables.
Next, check the settings on the transceiver to make sure that it is set to SSB mode. Sometimes, the mode settings can get changed accidentally, so it's important to double-check.
If the issue still persists, try resetting the transceiver to its factory settings. This can sometimes resolve any software glitches that may be causing the problem.
If none of these steps work, it's possible that there may be a hardware issue with the transceiver. In that case, it's best to contact a professional technician for further assistance.
3/28/2024 10:24:30 AM •
Radio...
Answered
21 hours ago
Serial Number for KPG-790
All questions need FULL 'make model (what it is) first 3 words please.
Something to do with this? The serial number should on the label on the rear by the mains cable. This is a statutory requirement unless someone removed it to hide its identity.
https://www.google.com/search?q=KPG-790
2/15/2024 3:06:45 AM •
Radio...
Answered
on Feb 15, 2024
