20 Most Recent Minolta MF1600E Plain Paper Laser Fax Questions & Answers
power supply fan motor
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Minolta MF1600E... | Answered on Feb 24, 2018
Go into the admin mode or user mode to reset the default settings. Procedure should be in the op manual.
Minolta MF1600E... | Answered on Jan 01, 2015
Mam Does other fax have different Phone number? Why not just swap the two fax machines? Are both machine using the same number or disconnect the 2800.
Is the drum 3rd party? if so it may not work, Mite have a bad Drum cart is it out of the box new. Take some alcohol and clean all the metal contact on the drum unit not the drum. Then reseat it.
have to go into service mode to change the setting for new drum. sir did you install a new drum or the toner cartridge to different parts
Minolta MF1600E... | Answered on Dec 28, 2014
When you copy? or when you print? If print OK check the doc feeder
Check the fusing unit and or transfer belt. Does it print OK not copy! Print Ok means internal OK then check the scanner section
Speed Dial Keys
The fax number and other data for a particular destination can be programmed using a 3-
digit Speed Dial Number. This feature allows you to transmit a document to the
particular destination by pressing the Speed Dial Key, entering the 3-digit number and
pressing the START Key. You can program a fax number in any of the 100 Speed Dial
locations, number 001 to 100.
Entering
1 Press the PROGRAM Key and scroll through the
menus until you reach the DIAL REGISTRATION
Menu. Press YES to begin programming.
2 Press 2 or scroll down to the Speed Dial menu and
press YES.
3 Enter the number of the location you want to
program and press YES.
4 Enter the Telephone number you wish to transmit
to and press YES after checking to see its OK. If
you want to enter the sub-address, press the Down
Arrow Key.
5 You can press sub-address up to 10-digit.
REGISTERED! KEEP?
OK=YES (EDIT/DEL=NO)
EDIT *DELETE
-SELECT&PUSH”YES”-
DIAL REGISTRATION?
YES / or 1-6
2 SPEED DIAL?
OK=YES
SPEED DIAL =_
OK=YES
OK=YES (SUB= )
SUB=_
OK=YES
Edit/Deleting
1 If you wish to change any entry, a screen allows you to accept or change.
2 If you wish to change a Key that was previously
programmed, this message appears. Press YES to
keep this location as is, or NO if you wish to edit it.
3 If you choose NO, use the arrow keys to select
either EDIT or DELETE and then proceed with the
needed changes.
Group Dial Keys
Instead of their regular functions, any of the One-Touch Keys can be used as Group Dial
Keys. Destinations already stored for One-Touch, Speed Dial can be entered in a Group
Dial Key. Each Group can contain up to 50 locations.
Entering
2 Press 3 or scroll down to the Group Dial menu and
press YES.
3 Press the One-Touch Key you wish to use.
4 Press YES to accept your selection.
NAME=_
OK=YES
REGISTERED! KEEP?
EDIT *DELETE
-SELECT&PUSH”YES”-
Minolta MF1600E... | Answered on Apr 18, 2010
http://www.smpcshop.com/MINOLTAFAX-2800-3800-p-1150.html
Minolta MF1600E... | Answered on Feb 02, 2009
yes you can! if you really want it! you may enter the menu and in printing menu look for rx and press enter, or look for print from memory! it should work
Minolta MF1600E... | Answered on Nov 04, 2008
You might try www.minolta.com to download a user manual. Otherwise you will have to scroll through the menus for SETUP
Minolta MF1600E... | Answered on Oct 20, 2008
clean rollers with alcohol, it should pick up ( for a while) rollers will probably need changing
Minolta MF1600E... | Answered on Feb 14, 2008
M2 Call service.Maintenance M2, M1 Call service errors.To remove this error do the following steps.1-Press utility button on panel.2-Now press these buttons one by one, Press Stop, then zero, again zero, then stop,then press zero.3-its the code to get into service mode.4-After pressing above mentioned buttons you will enter into service mode.5-Now select service choice option.select it by pressing OK button.6-In service choice option you will see Maintenance count option.7-Select it by pressing Yes or OK button.8-There will be three options 0,1,2.9-Select 1, it will show a new menu, with numbers, now press C button to clear the counter.After the counter is cleared.Select 0 and press Reset button.
Minolta Office... | Answered on Sep 09, 2019
Minolta MF1600E Plain Paper Laser Fax Logo
14 questions posted
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ed
Ed
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Minolta Office Equipment & Supplies
Most Popular Question
changing date minolta 2800 fax
  • Office Equipment & Supplies
