20 Most Recent
Carrera Chronograph Red LCD Watch for Men Questions & Answers
Did not receive owners manual when i purchased the
Copy the following into your search engine and it should take you to the watch you have and on the right is a menu which includes "user manual" which will give you all the information you need.
www.tagheuer.com/the-collection/carrera/men/automatic-chronograph-tachymetre/index.lbl?w=CV2013.FC6206
3/11/2010 8:46:40 AM •
Carrera...
Answered
on Mar 11, 2010
Tag carrera automatic stops at 12
It sounds like your Tag Carrera automatic watch may be experiencing an issue with the automatic winding mechanism. Here are a few things you can try to troubleshoot the issue:
- Make sure that the watch is fully wound. If the watch is not fully wound, it may not have enough power to keep running.
- Check the balance wheel and pallet fork for any debris or obstruction that could be preventing the watch from running.
- Inspect the winding rotor for any signs of damage or malfunction. The winding rotor may need to be replaced if it is not functioning properly.
- Check the control panel for any error codes or messages that may indicate the cause of the issue.
I bought my wife a
Hi
The mechanism of your watch is designed the way that it only rotates counterclockwise.However the stem should be pulled out, it could just be stuck but in order to adjust the time, you should pull it out.If you want to, you may bring the catch to a watch repair specialist and have the stem cleaned to that if you need to set the time, it will be easy to adjust it.
Be careful not to use anything sharp like a blade, you may risk remove the stem handle.
Let us know if you want to know something more else please accept the suggestion.
Thanks for contacting Fixya.com
How can you tell from a genuine or fake carrera
Paste this link into your browser and discover Carrera:
http://www.tagheuer.com/the-collection/carrera/men/automatic-chronograph-tachymetre/index.lbl?w=CV2010.BA0786
Fake watches are poorly made, writings are smudged, Watch itself is much lighter in weight than the original, movements are of very poor quality e.t.c.
The original watch oozes with quality and every tiny detail is superbly finished. All writings are crisp and sharp. Materials are of the top quality only.
Do not forget to rate, please.
My pearl necklace has broken
Contact a local jeweler and see if they do restringing. Most will charge approx $10 per inch.
Thank you for contacting FixYa.
Jewel
4/7/2024 2:26:15 AM •
Watches
Answered
on Apr 07, 2024
