pls help me how to registerd the headset with the base couse i forgot the pin number, my model its...
(More)
pls help me how to registerd the headset with the base couse i forgot the pin number, my model its siemens AL140 gigaset single pls pls
Dear all: I have a GE Cordless Telephone System, 40 Channel, 2.4 GHz, Model 27923. It worked...
(More)
Dear all: I have a GE Cordless Telephone System, 40 Channel, 2.4 GHz, Model 27923. It worked properly for a 6 month period, then stopped working. I thought it was the batteries and I replaced them, with appropriate polarity, but it didn't work either. Line and telephone source and cable are ok. If I call myself from the cellular it rings even if the handset is off the base cradle. But no voice at all, nor ring tone. What might be the problem ?? Thanks a lot for your support. Gilberto Landaeta gilbertolandaeta@hotmail.com
i accidentaly erased a message from my phone. is there any way to retrieve it? my phone is a...
(More)
I ACCIDENTALY ERASED A MESSAGE FROM MY PHONE. IS THERE ANY WAY TO RETRIEVE IT? My phone is a Panasonic KX-YG5671
How do I set the answering machine. I cant get the phone to pick up messages. I directly hangs up...
(More)
How do I set the answering machine. I cant get the phone to pick up messages. I directly hangs up when someone is trying to leave a message
GE 2.4ghz Handset #2 says "unavailable". Use to work fine. When power goes out, I have to...
(More)
GE 2.4ghz Handset #2 says "unavailable". Use to work fine. When power goes out, I have to set handset #2 it in the handset #1 cradle again to re-register it. Now it won't re-register. When I push the talk button, it beeps a couple of times and says "unavailable" on the screen. Thanks for any ideas or solutions.
Quero ver quem tem o manual em portugues do telefone GE sem fio 2.4 27928. para que ler e usar...
(More)
Quero ver quem tem o manual em portugues do telefone GE sem fio 2.4 27928. para que ler e usar corretamente.
THE DETECTIVE TRICK (Mobile Spying) Now you can spy on anyone using your cellphone. Just do the following. 1. Activate the "Automatic...
written by nicoleFIXIT
This happens when the first installation of the software had not been successful .
What usually happens is that wrong system registry cannot be...
written by ginko
Bought GE phone, 2 years later, will not record. My Tip is buy from a reputable company like one in Japan, big US corporations are in it for the stock...
written by tolong
GE branded Consumer Electronics are now sold by Thomson Consumer Electronics, Inc. Please call Thomson at 1-800-447-1700 for electronics product...
by Chicosat
