20 Most Recent Ariens Snow Blowers. Compact 24 in. Two-Stage Electric Start Gas Snow Questions & Answers
2answers
Grinding noise in housing of compact 24 snowblower
bearing shot blower or auger hitting housing
2/2/2015 8:39:02 PM • Ariens Snow... • Answered on Feb 02, 2015
Ariens Zoom 40 Zero-Turn Mower won't drive
https://lawnmodel.com/ariens-riding-mower-transmission-problems-fixes/#:~:text=A%20worn-out%20or%20broken%20drive%20belt%20will%20also,when%20the%20mower%20is%20running.%20Defective%20pressure%20switch
10/24/2022 1:19:00 PM • Ariens Garden • Answered on Oct 24, 2022
2answers
2answers
How does the drive belt go around the pully system on an Ariens lawn tractor
Go to this site: http://apache.ariens.com/cgibin/ctrg0005?SESSIONID=0.5721913612416231&Site=ARIENSS
7/14/2022 5:25:12 AM • Ariens Garden • Answered on Jul 14, 2022
Ariens EZR1540 blades won't spin.
https://www.tractorbynet.com/forums/threads/ezr-1542-blades-wont-engage.176529/
6/17/2022 9:12:59 PM • Ariens Garden • Answered on Jun 17, 2022
2answers
Why does engaging the mowing deck stall the engine SOMETIMES on my Ariens 46" tractor?
A snatching clutch is the most likely reason, or a dirty carburetor. Lots of help in the link https://www.google.com/search?q=engine+runs+fine+until+I+engage+the+mowing+deck ..
6/14/2022 5:21:04 PM • Ariens Garden • Answered on Jun 14, 2022
My blades won't engage on my ariens icon after it was cutting just fine. I accidentally killed the mower and tried to engage the blades and they won't niw
If you killed the motor by jamming the blades, the mower belt may have come off or broke. Check to see if it is still in place. Also with the engine off, turn the blades by hand and see if the upper pullies turn.
6/11/2022 2:32:44 AM • Ariens Garden • Answered on Jun 11, 2022
Mt ariens Ezra 1742 won't spark and start
Check the start relay (not starter solenoid) energizes during crank. If the start relay does not energize then the magneto kill shunt is closed, hence no spark.
Comment for further assistance.
6/4/2022 2:25:58 AM • Ariens Garden • Answered on Jun 04, 2022
Ariens snowblower 932102 auger will not stop spinning
It seems to be a common issue when you change a belt! Most people have it the other was when they won't turn. https://www.google.com/search?q=Ariens+snowblower+932102+auger+will+not+stop+spinning ..
2/2/2022 2:58:49 AM • Ariens Garden • Answered on Feb 02, 2022
8HP TECHUSEH ARIENS SNOWBLOWER CARB COVER REMOVAL
Did you remove the rear screw located beside the dipstick tube?
12/11/2021 1:32:06 AM • Ariens Garden • Answered on Dec 11, 2021
I have an ariens 1540 zero turn lawn mower just replaced the batter y was running son forgot to turn off mower blades now it wont start any ideas
Starter energize requires the following.
PTO - Off
Steering arms - Out
Ignition switch - Start position
Battery + fuse intact
Battery - fuse intact
Cycle PTO on/off, steering arms in/out. Check both fuses. Check battery voltage >12.0V.
12/6/2021 3:19:29 PM • Ariens Garden • Answered on Dec 06, 2021
2answers
3answers
Ikon Xl mower. when I try to start with the brake engaged, why doesn't it start?
perhaps the seat safety switch has dirt on the contacts
4/25/2021 11:10:01 PM • Ariens Garden • Answered on Apr 25, 2021
Ariens 1742- blades will only engage while moving. Once you bring arms to neutral the blades stop.
The problem likely is with the SEAT/PTO RELAY not remaining energize. Look for open or disconnected wire (PURPLE) from the relay towards the ignition switch.
See wiring diagram;
https://www.jackssmallengines.com/jacks-parts-lookup/manufacturer/ariens/zero-turn-lawn-mowers/ezr/915308-000101-ezr-1742-17hp-b-s-42-deck/wiring-diagram
3/21/2021 2:36:21 PM • Ariens Garden • Answered on Mar 21, 2021
2answers
My Ariens 924040 back fires when I try to start it with the electric start - WHY?
Ignition timing slightly out would be the main reason. Dirty spark plug is another Dirty carb is the last I thought of another. Failing battery. It doesn't have enough amps for cranking and spark.
12/24/2020 12:03:05 AM • Ariens Garden • Answered on Dec 24, 2020
2answers
46 riding mower. Why don't blades disengage?
BELTS BREAKING MANY TIMES TEARS WIRES LOOSE TO THE ELECTRIC CLUTCH
11/15/2020 6:04:02 PM • Ariens Garden • Answered on Nov 15, 2020
Model 915017 1542 zero-turn mower. How can I remove a deck pulley spindle?
See parts diagram
https://www.ariens.com/en-us/partsdiagrams?aribrand=ARN#/Ariens/915017_(000101_-_)_EZR_1542%2c_15hp_B%26S%2c_42%22_Deck/42%22_Mower_Spindle/6415040015/07200057/y
Likely you will need to remove the deck from the mower.
Then remove the blade, tray, and retainer to expose the woodruff key. Remove key and spindle should slide out of the spindle housing.
10/12/2020 1:48:57 PM • Ariens Garden • Answered on Oct 12, 2020
Ariens Snow Blowers. Compact 24 in. Two-Stage Electric Start Gas Snow Logo
4 questions posted
Top Ariens Garden Experts
john h
Mike Cairns
Mike Cairns
CJ Rock
CJ Rock
Are you an Ariens Garden Expert? Answer questions, earn points and help others
View Most Popular
Ariens Garden
  • Ariens Garden
Most Popular Question
snowblower sheer pin one blade gone but
  • Garden
