20 Most Recent GE WSKS2060WWH Top Load Washer Questions & Answers
Hope this video clarifies it: MY PAGE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
GE WSKS2060WWH... | Answered on Oct 07, 2012
Yes. Two ways to do it. I would use burst proof hoses first of all (the stainless braided style) I have seen lengths to 12' or couple 2 6 foot hoses with a threaded hose coupling. The drain hose is availible to any cut length at Home Depot or Lowes. Does not have to be the corregated plastic one , but one that is more kink proof the soft vinyl hose. Measure the ID (Inside diameter) to match up. Make sure you support the drain hose over that long distance since the drain water may weigh it down. Good luck!
GE WSKS2060WWH... | Answered on Jun 22, 2010
HI. the internal components that make up the agitator should be inspected for damage.
The agitator is fastened to the agitator shaft and its movement is driven either by splines or a simple clutch assembly. The splines are usually plastic or rubber nubs on a cylinder that fits over the agitator shaft. If the nubs wear down, the shaft will not turn properly or it will turn weakly. If the agitator is moving in only one direction, the likely cause is the clutch assembly. The clutch has dogs that depress and pop up with each turn. If those dogs are worn, they will not engage properly and the agitator will turn only in one direction. Another issue that might cause this disruption is the Motor coupler.
Washers with a direct drive motor have a motor coupler instead of a belt. The motor coupler consists of three plastic disks (or tri-stars) with interlocking tabs. Those tabs can wear and break which results in slippage. The slippage causes little or no power to be transferred to the transmission. A worn motor coupling can result in weak or no movement of the agitator and spin basket. Inspecting the motor couplers requires removing the motor, which is fairly easy to do.
Remove the cabinet. Locate the motor. The pump is mounted to one side of the motor. You do not have to remove the hoses from the pump unless they prevent you from moving the pump out of your way. If you must remove the hoses, label where they connect first. To disconnect the hoses, pinch the wire clamps with pliers (or loosen the screw) and slide the clamp farther up the hose. Slide the hose off of the pump port.
There are two clips that secure the pump housing to the motor. Use a screwdriver to pry up the clips and remove the cover. Next, slide off the pump to reveal the motor. Disconnect the wiring harness from the motor, do not pull on the wires themselves. The motor typically is secured with retaining clips and bolts. Remove the bolts and use a screwdriver to pry up the clips (if present). Remove the motor.
Mounted on the shaft of the back of the motor you will find the motor coupler. Separate the three disks and inspect them for damage. If you find cracks or excessive wear, replace the coupler.
**(((If the motor couple is in good condition, replace the agitator components and clutch assembly as well.)))
GE WSKS2060WWH... | Answered on Jan 07, 2010
one thing is wrong is balance.That's why it knock the wall down.Don't know to much about GE.But I would check the dasher to see if it's down.But the belt could be broken under the washer.
GE WSKS2060WWH... | Answered on Mar 13, 2009
Sounds like the spin coil/brake solenoid is burnt out or broken. This is a coil situated on the motor plate under the machine with a lever attatched to it. When the machine goes into spin cycle, this solenoid pulls the brake away from the outer drum to allow the drum and agitator to spin together. The shaft that goes into this coil should move in and out freely. If tight, replace spin coil/brake solenoid.
GE WSKS2060WWH... | Answered on Mar 03, 2009
possible faulty motor. Regards Advisor
GE WSKS2060WWH... | Answered on Dec 04, 2008
the washer has carbon brushes on the motor if these are low the drum will not spin it needs these carbons to make contact with the motor
GE WSKS2060WWH... | Answered on Oct 23, 2008
GE WSKS2060WWH Top Load Washer Logo
23 questions posted
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
jimorris77
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
GE Washing Machines
  • GE Washing Machines
Most Popular Question
everything working except spin cycle
  • Washing Machines
