20 Most Recent Nikon Coolpix P520 Camera - Silver 18.1Mp, 42Xzoom, 24Mm Wide Lens 3.2 Inch Lcd Questions & Answers
for joining files you may have to use a computer.....fade in or fade out is not available in p520....
Nikon Coolpix... | Answered on Dec 07, 2017
we would have no idea if they even know how to use it .
Nikon Coolpix... | Answered on Feb 19, 2017
you need to cut the picture with a program like photoshop, gimp or picasa, and then save it with a different name, or you will overwrite the original picture
Nikon Coolpix... | Answered on Sep 01, 2014
read the manual, or reset the camera
Nikon Coolpix... | Answered on May 25, 2014
upgrade the firmware?
Look in what part of the menu you are. If you are in Automatic scene or effects, you only can change few things. Only when you select P,S,A,M or U, you can set lots of things in he menu. Please look in the manual, because on your camera are so many things you can set, if in the correct menu or in the right settings menu.
Nikon Coolpix... | Answered on Dec 25, 2013
Do you have "Flash off" selected in menu? Also, if in manual modes, will not come up automatically. Try auto.
Nikon COOLPIX... | Answered on Jun 15, 2018
This camera does not have Manual Function. Your description sounds like the camera is OFF or needs to be RECHARGED. It seems dead to me - no power.
Nikon COOLPIX... | Answered on Dec 24, 2017
Yes - when editing images, always copy them to your computer and do it there. Do not copy the images back to the card, as the camera will be unable to read them - as you have discovered.
Nikon COOLPIX... | Answered on Nov 20, 2017
While a cable is connected to many Nikon cameras the screen shuts down.
Nikon COOLPIX... | Answered on Nov 11, 2017
before clicking any pic. format the card first.
Nikon COOLPIX... | Answered on Aug 24, 2017
Is this a card that has worked before and now doesn't? Do other card(s) work in the unit? If a card is attempted to be installed backward, it can damage the internal connections and make the card slot inoperative. Also, there are restrictions on the type, size, and speed of cards that can be used (identified) within the device. Here is a link to the manual; check page 20 of the technical notes and index (page 230 of the pdf).
http://cdn-10.nikon-cdn.com/pdf/manuals/coolpix/L820RM_EN.pdf
Nikon COOLPIX... | Answered on Jun 02, 2017
Coolpix Cameras are tricky to use with chargers. I will assume your USB Charger EH-69P is 100 - 240V 50/60 Hz so it CAN work in many places around the world with an adapter. Do not go over 240V or you could damage it.
These cameras like to have the power supply connected when it is on to charge - meaning if you have it connected and you plug the charger in the wall it will NOT charge. So if you plug the charger in the wall first and then plug the cable in the camera it will work. The camera is actually ON when it charges and I never REMOVE the memory card when it is ON.
When you have a dead battery. Plug the camera in and make sure the ON LED lights and the Charge LED flashes. Then don't mess with it. Let it charge completely (Charge LED stops flashing and is OFF) and then unplug it. It will turn off. Then later you can turn it on.
Nikon COOLPIX... | Answered on May 14, 2017
You can download manuals at NIKONUSA.com
Nikon COOLPIX... | Answered on Apr 15, 2017
Nikon Coolpix P520 Camera - Silver 18.1Mp, 42Xzoom, 24Mm Wide Lens 3.2 Inch Lcd Logo
9 questions posted
Top Nikon Cameras Experts
Steve
Jeff Marcus
Computer Links
Are you a Nikon Camera Expert? Answer questions, earn points and help others
View Most Popular
COOLPIX Nikon
  • COOLPIX Nikon
Most Popular Question
set up new nikon coolpix p520 now want
  • Cameras
