20 Most Recent
Canon ImageClass D660 Copier Questions & Answers
I need a driver software
What is the Operating system, win vista, win 7 , win 8 ??????The driver usually depends on the OS.
How to replace fuser canon d660
If you remove the left receiving tray, the printer port cover and the
upper cover above the receiving tray, you can get a right angle ratchet
screwdriver to remove the left screw and a stubby will get the 2 on the
right. Disconnect the 3 connectors and you can wiggle it out thru the
left side. I'm just starting one now.
I have a D660 printer,
I'm sorry, I believe the paper is in the fuser assy, correct? The whole fuser assy will have to be removed from the copier and taken apart to get the pieces of paper out. You will have to remove the left three covers, the cover just above the delivery cover and the small one just to the left of the delivery tray. Then remove the drum unit, the control panel, then the glass and the black cover for the ribbon scanner cable. Move the top reader assembly to the left so that the access holes align so that a long shafted phillips screw driver can be inserted to remove the three screws securing the fuser assembly. Then bend back the black milar plastic cover and unplug the three connectors that go to the fuser. Carefully remove the assembly and then remove the two screws at the top of the fuser and separate the assy. Reverse procedure. Good luck.
I've had several paper jams in the last few days.
this sounds like the timing sensor has been dislodged or damaged this happens when the paper is pulled out against the natural travel path of the paper. look for a broken off sensor flag or a flag that does not move frreely. if the paper is jamming close to exiting the printer check the fuser sensors for free movement. if its stopping more around the toner check the sensor above where the paper first comes out of the drawer. knowing where it jams would be of great help. hope this helps you
WHAT IS THE FUSER ASSEMBLY? hOW CAN i REMOVE PAPER JAM?
This is near the exit area right before copy exits into the tray or sorter It appiles heat and pressure to the copy as it goes between the upper and lower fuser rollers so that the toner melts into your copies and won"t rub off keeping the image from smearing Often the copies will be warm--this is normal.
Black Streaks
sounds like it needs a new drum ..you will need engineer to change
Need to download Imageclass D660 printer
try to add your printer just click start and then clickthe printer and faxs after that just add a printer, if it does not work try to see the device manager, you jsut right click the my computer then propertise, then hardware, then device manager, check if there is a yellow question mark, then try to right click it and update driver., then please restart to take effect.
How to slove error e732-001 of canon ir 3225
The E732-001 error on a Canon iR 3225 indicates an issue with the fixing assembly temperature. Here are some steps to troubleshoot and resolve this error:
Reset the Condition:
Enter service mode by pressing the following sequence on the control panel: COPIER > FUNCTION > CLEAR > ERR.
This will reset the error condition. If the message disappears, your printer is ready to use. If this doesn't work, there may be a hardware problem as addressed below.
Replace the Main Thermistor:
The main thermistor is responsible for temperature sensing. If it's faulty, it can trigger the E732-001 error.
Consider replacing the main thermistor to resolve the issue.
Check the DC Controller PCB:
If the problem persists, inspect the DC controller PCB for any defects or malfunctions.
Replacing the DC controller PCB may be necessary.
Remember to turn off the printer before performing any maintenance tasks. If the error persists or if you need further assistance, I recommend contacting your local authorized Canon dealer or the Canon Customer Support Center for professional service
