20 Most Recent
Gestetner AO45 Copier Questions & Answers
Blotching of ink on many
This happens when the waste toner is overflowing from wastage section. This overflow wastage toner spills on the paper and creates blotches.its a very common issue.
To solve the issue the wastage needs to be emptied and the unit should be cleaned and reinstalled safely.
Thanks. Keep updated for any more query. You can rate this
solution and show your appreciation.
How would I identify faulty fault sensors in gestetner MP2501L copier and replace them?
You can't. As I said you need the service engineer with the laptop. These Office Machines are NOT consumer serviceable. They hook up the laptop with the Ricoh software and it interrogates the computer, the mainboard and everything on it. The error message you get is from the brains inside it..Original question and answerhttps://www.fixya.com/support/t29802178-am_posting_again_stripped_off_gestetner..
Am posting again. I stripped off gestetner MP2501L 8 times due to problem ' see instructions on right side to solve' but same. No paper inside. What is the actual problem.
Hello Christopher
Are you in the Philippines? I notice that your copier has changed from Ricoh to Gestetner? We are a North American website.
This is a commercial office machine, and from my experience of them is that on the right side you will see on the inside, a list of instructions for where to check for obstructions. It seems you have already done this 8 times! Frustrating! Try this;
Open the right side cover, unlatch all the bits at that side.
Open the straight pass door on the left side.
remove ALL the paper drawers.
Get a powerful flashlight, look in all the spaces you have just created, especially at the edges of drawers and paper pathways. You are looking for a tiny piece of paper that one of your employees carelessly left behind after a paper jam.The one I found was right at the back of the straight pass door. When a sensor is covered, it creates that message.
If that fails, Ricoh will have to come and attach their Laptop scan software to it which will tell which sensor is obstructed or has failed.
Sc 569 for ricoh mp 5500
sc 569 is the pressure roller contact sensor error Troubleshooting Procedures: 1. Check or replace the harness of the pressure roller contact sensor. 2. Replace the pressure roller contact sensor. 3. Replace the pressure roller contact motor
SC 569 Error code in MP 5500
Ink idling problem in gestetner dx 2330 copy printer
Hi Hope this helps.The metal gauze filter (see image) behind the input nipple on the drum unit may become blocked with congealed ink deposits causing the ink not to feed at full flow.Strip and clean the blocked gauze filter in the Ink Supply System.
Gestetner DX 4542 not supplying ink
Ink pump motor may be not working first you need check your cp is original.. After that remove drum unit disabled the unit and clean ink detection sensor and ink pump motor
