20 Most Recent Eiki XGA Avanti Series LCD Projector Projector Questions & Answers
How do you turn on the cooling fan on a lc xa20?
If the cooling fan is not on, it is probably faulty and needs replacing or is jammed up.
Check the air filters are not clogged up.
1/3/2011 4:57:03 PM • Eiki XGA Avanti... • Answered on Jan 03, 2011
My EIKI projector won't turn on.After hitting the power button it will begin to start but after about 10seconds the fan will start running real fast and then will stop and the warning light comes on.
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel, motherboard, powersupply ... with high quality and competitive price. Jerry Lampdeng Limited WhatsApp ID:+8613178867858 Skype:[email protected] Wechat ID:+8613178867858 Email:[email protected] Email:[email protected] Mobile:+86 13178867858 http://www.lampdeng.com
6/11/2019 7:49:02 AM • Eiki Office... • Answered on Jun 11, 2019
I can only select 108i on my eiki LC X60 when using hdmi from cable box into dvi adapter into dvi input on projector. Also pictue is smaller.
Try different source (laptop HDMI) to mske sure it is not cable box issue
1/13/2018 11:47:25 PM • Eiki Office... • Answered on Jan 13, 2018
0answers
Light stay on
possibly max lamp usage hours have been exceeded
5/4/2016 11:29:19 AM • Eiki Office... • Answered on May 04, 2016
Why is my orange light blinking
Please lets know the model
3/23/2016 10:28:29 AM • Eiki Office... • Answered on Mar 23, 2016
LC-XNB4MS projector has a yellow
this has soething to do with bad timing of the lcd panels on the prism block. This is a common problem for this model. You will have to replace the entire optical, which is very costly. better invest your money in a newer model
4/17/2014 1:04:45 PM • Eiki Office... • Answered on Apr 17, 2014
I have an eiki lc
this depends on the signal type coming from your sources best is using component signal ( Y-Pr-Pb) , by using the right cables and right settings for video inputs in the projector menus.In basic this should be possible.
4/17/2014 12:41:41 PM • Eiki Office... • Answered on Apr 17, 2014
Projector causes buzz in sound
buzz in sound is often caused by ground-loops, try to isolate audio cables with so called groundloop isolator transformers ( 1:1) available at high end audio shops or car audio centres
4/17/2014 12:25:14 PM • Eiki Office... • Answered on Apr 17, 2014
Model LC-XBM31 The projected image
yellow means lack of blue. maybe a bent pin of the signal ( VGA) cable
4/17/2014 12:08:41 PM • Eiki Office... • Answered on Apr 17, 2014
I have a Eiki Projector
burned in green polarisers or lcd panel. or accumulated dust on optical parts.
4/17/2014 10:42:30 AM • Eiki Office... • Answered on Apr 17, 2014
Eiki XGA Avanti Series LCD Projector Projector Logo
1 questions posted
Top Eiki Office Equipment & Supplies Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you an Eiki Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Eiki Office Equipment & Supplies
Most Popular Question
turn cooling fan lc xa20
  • Office Equipment & Supplies
