20 Most Recent
Toshiba TDP-T9 DLP Projector Questions & Answers
My fan keeps going on and off
I had one do this in the past. I ended up using an air can to free the fan parts of dust. Have not had an issue after that.
I have connected my toshiba TDP-T9 to my laptop
Depending on your laptop, the internal splitter may be turned of. Usually the keystroke to turn it on is Fn F8. However it may be different on your laptop. Look at the function buttons, and the one with a screen looking thing on it is the one you press with your "Fn" key.
How do we reset Toshiba eStudio 456SE?
https://www.google.com/search?q=reset+Toshiba+estudio+456se
Error Code Toshiba E-Studio 356Se F510
Copytechnet
https://www.copytechnet.com > ... > Toshiba
Jun 17, 2015 - Assumes that u already reboot the machine, same error occur, then u can proceed to reinstall HDD software. Is still persists, u need to format ...
Dead Machine Toshiba e-Studio C4540 F510
Dec 6, 2012
Error Code F520 in Toshiba E-Studio 356Se
Jun 18, 2015
Toshiba estudio 456 giving an error code f106
Oct 6, 2020
Error Code Toshiba e-studio 5540 again...
Apr 26, 2023
More results from www.copytechnet.com
Missing: 456se ' Show results with:
456se
Error Codes > Toshiba > e-Studio 456 > page 1
Printcopy.info
https://printcopy.info > brand=Toshiba
Code: C010; Description: Main motor abnormality: The main motor is not rotating normally. Causes: Main motor LGC board; Remedy: 1 Is the main motor working?
How do i fix error code f510 for toshiba e studio 3040c
https://www.fixya.com > ... > E-Studio 3040c Color Copier
Jan 18, 2016 - You can try clearing the code using this reset procedure: (1) Turn the power ON while [0] and [8] are pressed simultaneously. (2) Key in "400", ...
Error Codes > Toshiba > e-Studio 2518A > page 44
Printcopy.info
Code: F510 · Description: Application start error · Causes: The application fails to start. · Remedy: 1. Reboot. 2. If it has still not recovered, reinstall the ...
456se
Toshiba e-STUDIO 2555C Service Manual page 791
ManualsLib
https://www.manualslib.com > ... > Service manual
[F510] Application start error. Classification. Other service call. Check item. Setting. [F520] Operating system start error. Classification. Other service call.
HI! toshiba copier shows error code of C3B0. what is the solution?
That depends on the printers model
One could be;
Check to see if the waste bottle is overfull.
If yes, the waste toner will be backed up into the waste tubes, first affecting the primary transfer cleaner unit, then the black drum cleaning unit, then the color drum cleaning units.
Or;
Developer unit • Check if the developer unit is installed properly. • Check that the developer unit and coupling on the equipment side are properly engaged. • Check that the mixer of the developer unit is rotated. • Check if the developer material is too dark visually. • Check if the amount of the developer material is too large or too small. • Remove any toner or dust on the ATC sensor connector and the drawer connector of the process cover. • Remove any toner or dust on the EPU sensor connector and the drawer connector on the equipment side.
Or;
Auto toner sensor Harness LGC board • Check the connectors and harnesses between the auto toner sensor and LGC board (CN364). • Check if there is any foreign matter such as toner in the connector of the auto toner sensor. Remove if there is and reconnect it.
Toshiba error e010
https://printcopy.info/?l=en&mod=erc&brand=Toshiba&model=e-Studio%20556&code=E010
Quoting from link above:
Code
E010
Description
Paper not reaching fuser transport sensor: Paper which has passed the fuser unit does not reach the fuser transport sensor.
Remedy
Open the jam access cover. Is there any paper on the transport path or in the fuser unit? ? YES ? Remove the paper. NO Is the fuser transport sensor working? (Perform the input check in the test mode: 03-[FAX]OFF/[7]/[C]) ? ? NO ? 1. Check if the connector of the fuser transport sensor is disconnected. 2. Check if the connector CN332 on the LGC board is disconnected. 3. Check if the connector pins are disconnected and the harnesses are open circuited. 4. Check if the conductor pattern on the LGC board is short circuited or open circuited. 5. Replace the fuser transport sensor. 6. Replace the LGC board. YES Is the transfer belt working? ? ? NO ? 1. Check if the connector of the transport belt is disconnected. 2. Check if the connector on the transport motor driving PC board is disconnected. 3. Check if the connector CN341 on the LGC board is disconnected. 4. Check if the connector pins are disconnected and the harnesses are open circuited. 5. Check if the conductor pattern on the LGC board is short circuited or open circuited. 6. Replace the transport motor driving PC board. 7. Replace the LGC board. YES Is the drum separation finger solenoid working? (Perform the output check in the test mode: 03-111,161) ? ? NO ? 1. Check if the connector of the drum separation finger solenoid is disconnected. 2. Check if the connector CN339 on the LGC board is disconnected. 3. Check the installation state of cleaner. 4. Is the relay connector connecting the cleaner unit and the equipment disconnected or stained with toner? 5. Replace the drum separation finger solenoid. 6. Replace the LGC board. YES Is the registration sensor working? (Perform the input check in the test mode: 03-[FAX]ON/[4]/[E]) ? ? NO ? 1. Check if the connector of the registration sensor is disconnected. 2. Check if the registration sensor is installed correctly. 3. Check if the registration actuator is operating properly. 4. Check if the connector CN341 on the LGC board is disconnected. 5. Check if the connector pins are disconnected and the harnesses are open circuited. 6. Check if the conductor pattern on the LGC board is short circuited or open circuited. 7. Replace the registration sensor. 8. Replace the LGC board. YES Is the registration motor working? (Perform the output check in the test mode: 03-108/158) ? ? NO ? 1. Check if the connector of the registration roller clutch is disconnected. 2. Check if the connector CN341 on the LGC board is disconnected. 3. Check if the connector pins are disconnected and the harnesses are open circuited. 4. Check if the conductor pattern on the LGC board is short circuited or open circuited. 5. Replace the registration roller clutch. 6. Replace the LGC board. YES Check if there is any abnormality in the space between the registration motor and the registration roller (metal). Check if the registration roller (rubber) is rotating smoothly. Check the condition of the registration roller at the horizontal transport section and clean or replace it. * If the error [E010] caused by a paper jam underneath the drum cleaner often occurs due to an insufficient paper separation from the photoconductive drum, set a smaller value in the code 08-841, and see what happens. At this time, however, pay attention to the transferability at the leading edge of the paper since this transferability can be slightly narrowed depending on the environments and conditions under which the equipment is placed or the media type of the paper used. (Refer to 3.6.1 in this manual about the details of the code 08-841.)
