20 Most Recent
NEC LT260K DLP Projector Questions & Answers
Nec lt260 turns on but has a display problem
Hello.
Some suggestions from NEC support:
Use the menu to select your source (RGB 1/2, Video, S-Video, Viewer or LAN).
• Ensure your cables are connected properly.
• Use menus to adjust the brightness and contrast.
• Remove the lens cap.
• Reset the settings or adjustments to factory preset levels using the Factory Default in the Adjustment Menu.
Hope this helps.
NEC LT260 Powers on and
Yes, the control processor of the printer has failed. Since the only way to replace it would be to replace the entire mainboard it means that the projector is dead, time for a new one.
NEC projector M322X indicates light but cannot turn on
Based on the information provided, it is possible that there may be an issue with the projector's power button or internal components. It is recommended to try the following troubleshooting steps:
1. Check the power source: Ensure that the projector is properly plugged into a working power outlet and that the outlet itself is functioning correctly.
2. Reset the projector: Some projectors have a reset button or option in the settings menu. Try resetting the projector to see if this resolves the issue.
3. Check for internal issues: If the above steps do not work, there may be an issue with the projector's internal components. It is recommended to contact a professional technician or the manufacturer for further assistance.
In summary, if a NEC projector indicates light when plugged into a power source but does not turn on when the power button is pressed, it may be due to issues with the power source, internal components, or other factors. Troubleshooting steps such as checking the power source and resetting the projector may help resolve the issue, but professional assistance may be required if these steps do not work.
NEC NP310 projector, can I replace the fan?
Your statement indicates'there is a fan issue'.
It may just require cleaning but may need replacing. Nothing to do with the lamp, unless it has overheated and also needs replacing.
