FixYa.com
GE 21.9 cu. ft. / 620 liter Upright Freezer ZIFS36NMLH
All Products > GE > Freezers
Problems with GE 21.9 cu. ft. / 620 liter Upright Freezer ZIFS36NMLH?
Search inside GE 21.9 cu. ft. / 620 liter Upright... Knowledgebase
Troubleshooting and Support
Solved Problems for GE 21.9 cu. ft. / 620 liter Upright Freezer ZIFS36NMLH RSS Feed Post a New Problem
Does my freezer require any routine...
Does my freezer require any routine maintenance?
1 Solution
fridge not COOLING
whirlpool fridge not cooling ,defrosted, light still on
1 Solution
hole in the bottom of freezer
i have made a small hole (about 8mm long in the bottom of my freezer and the gas came out of it. will it work if i find...
1 Solution
Old Frigidaire Upright Freezer
I was given an old Frigidaire upright freezer that was in working order. After getting it home it was recommended that...
1 Solution
1999 Suzuki King Quad with broken...
I have a 1999 Suzuki 300 King Quad with a broken speedometer cable. I purchased the replacement cable from the dealer,...
1 Solution
leak
i have a kdx 200 dirtbike , and after i ride it it leaks something out the air cleaner, i took the filter off , and...
1 Solution
freezer not cooling down
I turned freezer off to defrost . After I hand dryed it I turned it on but it isn`t cooling down or the sucktion isn`t...
1 Solution
View All
Tips & Tricks
Post a New Tip
Specifications
Key Features
Temperature ControlWith Temperature Control
Freezer TypeUpright
Volume21.9 cu. ft. / 620 liter
Defrost TypeFrost Free
Other Features
Door LockWithout Door Lock
Dimensions
Overall Depth24.75 in.
Overall Height84.0 in.
Overall Width36.0 in.
Warranty
Warranty5 Years
GE Contact Information
Main support number1-800-626-2005
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
