20 Most Recent
Broan-NuTone N-GF900N Gable Fan Attic Fan Questions & Answers
I need a belt for a very old attic fan. The belt
I have an old robbins and myer attic fan. The motor is bad and there is no sticker let on the moter saying what hourse power or voltage the fan is. The model number is BV24. I couldnt find anything on the web about this model. Does anyone have a clue what kind of motor i need
Broan bath fan motor has bad bearings.
The motor is usually not repairable. You can sometimes purchase the motor and fan separate but that is about it. Here is a link to a blog about replacing motors.
http://nutoneproducts.blogspot.com/2009/05/broan-bath-fan-motor-replacement.html
How to change the light bulb?
Pull the cover from each side directly straight down. The cover will come down about 2 inches. Reach up on either side and squeeze together the spring to release it from the housing. The cover will swing down. Replace bulb. Squeeze the spring back together and initiate it into the housing. The last step is to push vertically the cover back up in to the housing.
How do i remove the blower wheel from a broan 684 bath fan
There are a number of YouTube videos that show how to replace the motor assembly on a Broan bath fan. Once you have unplugged the fan and removed the motor mounting plate you will have easy access to replace the blower wheel and/or the motor assembly.
Just go to You Tube and search on Broan
