FixYa.com
Easy Flo EF1425 Central System Vacuum
All Products > Easy Flo > Vacuums
Problems with Easy Flo EF1425 Central System Vacuum?
Search inside Easy Flo EF1425 Central System Vacuum Knowledgebase
Troubleshooting and Support
Solved Problems for Easy Flo EF1425 Central System Vacuum RSS Feed Post a New Problem
Hoover model 5906-900 spinscrub
The brushes have stopped moving, what can I do? The machine still works, sucks etc. Just doesn's scrub anymore. Thanks...
1 Solution
Unable to Extract Water
I am able to shampoo but the unit is not extracting the water from the carpet.
1 Solution
Black And Decker Gw150 Forgotten How To...
I have had this model for several years but have not used for a while. I was wondering if you could help me start...
1 Solution
Kirby Vacuum Shampoo Attachment
Power is going to the vac when shampooer is attached but it will not go on.
1 Solution
Oreck Vacuum troubleshooting
My Oreck Upright has started spitting out what I want it to suck up. I'm going to try replacing the belt, but someone...
1 Solution
changing the belt
I have an old dirt devil(model#5200)I think the belt might be broken but I can't get the bottom off, whats the secret?
1 Solution
My Hoover runs at a high rpm
When I start up my Hoover vacuum cleaner, it revs up to what sounds like an unsafe rpm. What could this be?
1 Solution
View All
Tips & Tricks
Post a New Tip
Specifications
Key Feature
DesignCentral System
Tank / Bag Capacity5 Gallons
Motor
Amperage13 Amp.
Motor Stages2
Suction
Air Watts524
Waterlift125 in.
Airflow125 cfm
Warranty
Warranty2 Years Parts, Lifetime Labor, Lifetime Motor
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
