20 Most Recent
HTC Touch Diamond P3700 Cell Phone Questions & Answers
Language change english
keep searching 'setting'
language option always comes with
A
Changing keyboard language
You can choose between a wide variety of languages, layouts and regions for your keyboard, so you can find the appropriate letters, characters, symbols and abbreviations. Your phone also offers word suggestions and spelling corrections based on the language you choose.
- On Start, flick left to the App list, then tap Settings > Keyboard.
- Select all the languages you'd like to be able to use from your keyboard.
The next time you use your keyboard, you'll see a button next to the Space bar that indicates which language you're currently using on your keyboard.
- Tap the button to switch between all the languages you've selected. For example, if you usually use a US English keyboard, tap the ENU button, and the keyboard switches to the next language you've selected.
Note
Some phones may not include all keyboard languages.
12/26/2013 10:49:14 PM •
HTC Touch...
Answered
on Dec 26, 2013
I set a cosecurty code
Are you sure you enter correct code? IF yes maybe your phones need to be reset. Try to call your network provider and asking him about
HTC Touch Diamond P3700 unlock code, don't forget to explain your situation and you need needs 1-2 weeks before you get that code and it takes a charge. Or you can try buy instant
HTC unlock code from third party sites with lower price and more quick turnable.
9/13/2011 11:48:46 AM •
HTC Touch...
Answered
on Sep 13, 2011
I have an Htc touch
Have you done a full factory reset? I was out of technical support before the Windows OS was released but it sounds like something may be corrupted. I would contact your service provider and request a full factory reset.
Rylan
12/16/2010 9:41:28 PM •
HTC Touch...
Answered
on Dec 16, 2010
Suddenly wlan cannot on, when I go to comm manager
They Don't tell you this in the manual but it's very IMPORTANT.
If you set up like this you won't get automatically connected via your Telco’s data connection (unless you chose to):
1. Go to start/settings/connections and click 'Wi-Fi.
Click 'Wi-Fi' and from the drop down menu chose 'Work' (not 'The Internet') then click 'OK'.
(Seems crazy I know but that's WM terminology for you).
2. You should still be in start/settings/connections/ so click 'Connections' the 'Advanced' tab.
click 'Select Networks' and set both boxes to 'My Work Network'.
Click OK.
3.
Now when you click Settings/Communications (in Touch Flo desktop) and
turn on Wi-Fi every app that connects to the internet will
automatically connect via your WiFi connection.
4. If you need to connect using your Telco’s Data connection (should you be away from a WiFi router:
From Settings/Communications click then 'Select Networks' and in the
top box choose 'internet' or ('Optus internet settings' in my case).
Remember to disconnect using 'Select networks switch' and change it back to 'My Work Network' as per step 2 once your finished.
also
While Playing and searching around with ur HTC and with the WLAN
settings in ur phone. it just so possible that u changed ur power
settings.
Here are the procedures.
- Go to START
- Settings
- COnnections
- Click the WiFi icon
- Go to advanced
- Click the (Power mode) Below the screen
and you will be prompted in the POWER SAVE MODE choose BEST PERFORMANCE
go to start>Settings>Connections>Wifi>Network Adaptors>IEEE 802.11& choose "Obtain IP automatically"
try restarting your device& the router itself..
i
would recommend that you turn off authentication/encryption& key on
your wifi network& try to connect..if it did connect with your
touch pro..try to enable each security item one at a time..
if you still cannot connect, I would recommend that you try to connect to any other wifi network..
if its no use still.... we recommend u contact HTC.. as it cud be a hardware problem....
thank you for using fixya...
have a nice day and good luck
7/11/2009 11:56:04 AM •
HTC Touch...
Answered
on Jul 11, 2009
What is the Telus network unlocking code for an htc phone
Only Telus can unlock it and only if the rent to own contract is paid off. If you take it to a third party unlocker, Telus can still lock it on you by using the IMEI number.I would urge you to edit out your IMEI number as it can allow the unscrupulous to clone your phone and make calls at your expense.
