20 Most Recent Acer X203W 20" LCD Monitor Questions & Answers
I got a acer x203w
try to adjust its resolution as manual instructions says
3/31/2011 6:29:16 AM • Acer X203W 20"... • Answered on Mar 31, 2011
"my pictures" photos of people are shortened and
Tried changing the aspect ratio of the display?
1/1/2011 7:31:30 PM • Acer X203W 20"... • Answered on Jan 01, 2011
My screen turned red...Why is that?
the cable of the that lead to the lcd and computer might not be properly inserted or the cable might be damaged
9/28/2010 10:43:19 PM • Acer X203W 20"... • Answered on Sep 28, 2010
My acer monitor X203w has a pink rather than white
The pick tint is caused by the backlights not going to full brightness. It is going to be either the back light tubes or the power supply/inverter board. Your monitor should still be under warranty with Acer so you need to contact them and get it serviced. The longer you wait the worse the tint will be until the monitor quits working all together.
Buddy
Corporate Computer
www.ccl-la.com
1/21/2010 4:29:53 PM • Acer X203W 20"... • Answered on Jan 21, 2010
The right side of my
How long have you owned the monitor and how long have you had this problem? Did you change any settings on your computer? Once I have more information I can assist you further. Do you have availability to another computer to try the monitor on that computer. Then you can isolate whether its a problem with the monitor or a problem with the video settings.
Thank you,
lee
11/9/2009 4:29:51 PM • Acer X203W 20"... • Answered on Nov 09, 2009
Have black area on right side of screen and can't
What video-card does your computer have?
Some older video-cards do not support "wide-screen" monitors.
Thus, they only "paint" 80% of the width of the screen.
10/9/2009 2:50:43 AM • Acer X203W 20"... • Answered on Oct 09, 2009
I recently got a 1600x900 monitor and on the
If the monitor came with a drivers or profile disk, make sure to use that. Also, make sure the video card can run at that resolution. Check with the system or video card manufacturer.
You may want to post what kind of (a) system (for instance, "HP Pavilion D1321" (to make one up) ) and/or video card (from display properties - "Plug and play monitor on nVidia MX400") as well.
10/3/2009 9:11:18 PM • Acer X203W 20"... • Answered on Oct 03, 2009
I hit some combination of keys by mistake, and not
http://support.acer.com/acerpanam/manuals/acer/0000/userguides/X203W_UG_EN.pdf
Try this user guide...page 13, I believe. Hope this helps
8/18/2009 12:41:17 PM • Acer X203W 20"... • Answered on Aug 18, 2009
2answers
Monitor will not display full screen.
Usually there is a adjustment tool built in with your monitor who let you adjust this. You will be able to move it up-right-left-right along with a few other options about brightness/contrast, gamut and so on. Let me know if you still need help with this
6/8/2009 8:32:17 PM • Acer X203W 20"... • Answered on Jun 08, 2009
Forgotten password
I use a program called "locksmith" which is included on a "commander disk" that I have.
you can check at :
http://www.bootcd.us/ERD_Commander_2003.php I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
4/23/2024 9:24:47 PM • Acer Computers &... • Answered 15 hours ago
My new-bought Acer Aspire 3 has yellow acer logo when starting up, is it normal? Because in some yt videos, the acer logo is green
Perfectly normal. It depends on the internal timing of the GPU and the OS version.
4/17/2024 3:01:26 AM • Acer Computers &... • Answered on Apr 17, 2024
tip
Mpowering technology pop up
Couldn't get rid of mpowereing technology pop up. Tried every solution offered by the internet. Finally I noticed when I powered up my computer the pop up showed up even before the computer loaded anything. I turned off the power to the monitor and powered it back up an viola, pop up gone. The Acer monitor had generated the pop up.
2answers
My Acer X1110 switches off as soon as blue light comes on?
it needs service, and service manuals are hard to find on anything by the likes of ACER. this projector worked for 12 long years, did you own it 12 or bought a bad projector, no history told as I can buy dead projectors all day long. and hard nut problems even hacking done. Acer X1110 data projector Standard throw projector.. did you know most projectors have serious grade protective devices inside??? (tamper and overheating are 2) did you read owners manual page 32 yet, errors. LED codes.? there are 4 LED, and all 4 matter, projector turned (ON) (not one =1) also in pairs glowing and also if blinking or not, so read page 32 it tells all that. my guess is overheat failures, even cold, due fan slow or packed in lint after 12 years of use and no service done,. color-undefined-undefined-0.jpg https://manualzz.com/doc/49497108/acer-x1110-user-manual some have dust filtler a shop first cleans is out first, and check fan RPM with and LED tachometer. this is all SOP.
4/2/2024 4:37:58 PM • Acer Computers &... • Answered on Apr 02, 2024
''e'' button :acer empowering technology
That button can be set using the utility on your programs list
It maybe that you accidentally turned it off or set it to do some other task.
Start there first before re-installing the program that sets it.
That is on one of the cds that should have come with it and can be installed by itself.
1/25/2024 8:38:32 AM • Acer Computers &... • Answered on Jan 25, 2024
Gud day my motherboard model is acer b25h4-am pc i forgot the password in bios so i decided to clr_cmos jumper and take out the cmos battery to clear the password of my bios,
I would try starting up and go straight into the BIOS. Set up your system and reboot.
1/23/2024 7:25:53 AM • Acer Computers &... • Answered on Jan 23, 2024
2answers
I can't use bluetooth on my Acer Aspire 7520
This computer does not have Bluetooth capabilities and you can't make it, by adding a Bluetooth Driver. It would need a Bluetooth transmitter and receiver HARDWARE built into the computer at the time of manufacture.. https://icecat.biz/en/p/acer/lx.akg0x.146/aspire-notebooks-aspire+7520-6a2g16mi-1376542.html and this site actually says it. https://www.bhphotovideo.com/c/product/538918-REG/Acer_LX_AN20X_017_Aspire_7520_5757_Notebook_Computer.html/specs Wireless Wi-Fi: 802.11b/g Bluetooth: None ..
11/27/2023 12:05:13 PM • Acer Computers &... • Answered on Nov 27, 2023
Acer X203W 20" LCD Monitor Logo
16 questions posted
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
View Most Popular
  • Acer Computers & Internet
Most Popular Question
resolution set correct screen res in
  • Computers & Internet
