20 Most Recent HP Officejet Pro 850 InkJet Printer Questions & Answers
If you are getting a 'carriage jam' error as soon as you turn on your printer with no tasks in progress, then check for any piece of paper stuck in the carriage. Remove the paper carefully. If the paper tears, part of it might remain inside the paper path and damage the product.
Follow the steps for fix HP Printer Carriage Jam
  • Turn off the printer and open it to see where the paper is stuck.
  • Manually move the carriage toward the opposite side.
  • Check the paper path and remove any piece of paper or any other object that is stuck in the path.
  • Reconnect the power cord and turn on the printer.
http://www.fixya.com/support/t6088190-hp_7400_displays
HP Officejet Pro... | Answered on Apr 14, 2014
If you have already removed the paper from the printer, and there is no longer any jammed paper in the machinery, try turning the printer off for 10-15 seconds and then turning it back on.
HP Officejet Pro... | Answered on Mar 03, 2011
did you switch the machine on and off
one of the paper sensors may be stuck pr damaged
HP Officejet Pro... | Answered on Feb 14, 2011
There are couple of sensors on this printer.
Please could you give us more infomation on the fault
you are expreriencing.
One of the paper sensors may be stuck or damaged
Welcome to Fixya
Try to drain the remaining electrostatic charge on the board. Unplug the power adapter from the printer and press and hold the power button for 15 secs. Plug everything back in and tun on the printer. I provided you a link from HP for further troubleshooting regarding this particular issue.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
HP Officejet Pro... | Answered on Feb 05, 2011
Do a L3 Uninstall first for the previous software. But Before Doing so, download the updated software first.
To Download:
1 Go to hp.com 2 Click on Support and Drives 3 Enter your product name or number, in this case just type in Officejet 8500 All-In-One 4 Hit go 5 Choose your operating system 6 Hit Next 7 Click on the link that says Driver - Product Installation Software 8 Save it to your desktop
Once the download is finished for the L3 Uinstall:
Insert the CD that came with the Printer in your computer disc tray --
1 Go to My Computer (XP), Computer (Vista and Win7) 2 Right Click on the Driver CD, The one that has the HP Logo 3 Open Util 4 Open CCC 5 Double Click on the icon that says Uninstall_L3
I hope this helped.
HP Officejet Pro... | Answered on Feb 04, 2011
then your other color may be low, or the cartridge is faulty or your ink station is not recognizing the ink, this you should refer to the vendor as your printer may be under warranty and it can be replaced with a new printer
HP Officejet Pro... | Answered on Aug 05, 2010
while scanning try reducing the DPI of the scans. this will make the image smaller in size but it will effect the picture quality very little. but do keep in mind that the dpi must be atleast 70 for better picturization
HP Officejet Pro... | Answered on Jun 28, 2010
Tip
Where to find the manual (pdf) for HP Officejet Pro 8500 multifunction printer
Sometimes , it is convenient to have a soft copy of your user manual. You may also require it as you lost your original printed manual. This tip will guide you to your digital manual and explain how to download it.
Printed manuals are normally available at a cost from the product manufacturer. Please see the link below to contact the manufacturer and find out how to replace your printed manual.
To download a soft copy of your manual , please Click Here to go to the retrevo page for your manual. This is a excellent site that maintains a manual and product database of thousands of products available free to download in PDF format.
Please note that you will need pdf viewer software to be able to view the downloaded manual. I can recommend Adobe reader which is available for free download at the following location :
CLICK HERE to go to Adobe Reader download site.
To download you manual from retrevo , follow the above mentioned link.You will be taken to the product page. The following images are used as an example.
When your on this page , you can select to see reviews , prices , specs , an overview of the product and of coarse , the manual. You can just hit the big red manual button to proceed.
Now simply type in the capcha code and hit the red “download now” button to begin your manual download.
To go to the manufacturers website , click on the link below:
Canon USA
Canon Global
HP
Epson
Lexmark
Samsung
Brother
Please rate this tip if you found it useful.
Kind Regards
StephanSA
on Mar 07, 2010 | HP Officejet Pro 850 InkJet Printer
Hi .
It still looks to me as it is blocked some where so I would try.
Ok it got to be the heads blockage
There is fluid cleaner for this but I can never find any in the shops the only ones I seen is when they sell them in Tesco but they come in with the ink refill bottles so I just use worm water by it self on a cloth and dabbing on the heads to clean them, it will not harm the heads but not to much water.
Some heads are on the inks them self but some have them inside the printer so I not know your printer so if the heads are inside you need to get them out you may find that some heads will just clip out put some need to be unscrewed so you got to know how they come out so be careful and not push to hard on them, if the heads are on the ink then it is a easy job to clean them,
It worth a try it worked for me more than ones.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
HP Officejet Pro... | Answered on Feb 02, 2010
You need to get more RAM & increase the size of your hard drive space... this is usually why. Not enough Ram or HD space.
HP Officejet Pro... | Answered on Jan 31, 2010
Ahhh. A fellow OfficeJet 4652 owner. I own one too. In your print driver, you want to click quality, and then normal.
HP OfficeJet... | Answered on May 31, 2019
HP Officejet Pro 850 InkJet Printer Logo
Popular Tags
25 questions posted
Clive
Clive
Thomas F. Schneider
View Most Popular
OfficeJet HP
  • OfficeJet HP
Most Popular Question
carriage jam
  • Office Equipment & Supplies
