20 Most Recent Curtis MPK2066 MP3 Player Questions & Answers
I had the same problem but have now resolved as follows. Turn the top switch to on and connect via USB port. Picture should come on the mp3 player indicating it is connected. For some reason unknown to me in order to charge you need to turn the MP3 player on - but this is impossible if there is no charge. What you need to do now is leave the MP3 player connected like this overnight - it will then have gained enough charge in the morning so that when you then disconnect the MP3 player from the USB lead you are able to actually turn it on. PLEASE NOTE this is not turning on by the switch at the top. What you do it press and hold the circle/dash symbol i.e. at the bottom of the white keypad bit on the front of the MP3 player. As you then let go it comes on. Let it finish turning itself on, then reconnect to the USB lead and leave over night to get a full charge. Good Luck
Curtis MPK2066 ... | Answered on Oct 18, 2011
may be your old usb kabel has a problem.
,you have to provide new usb kabel.
,if nothings happen.
,any of this 2 problem the switch or on your mp3 usb connectio.
Curtis MPK2066 ... | Answered on Apr 13, 2011
Hold Play/ Pause button and then press Previous/ Next button to volume up/ down.
Curtis MPK2066 ... | Answered on Apr 10, 2011
P/L CHEAK YOU SYSTEMS WIN98,99,OR 2000 MP3 SUPORTED FROM WIN 2000
Curtis MPK2066 ... | Answered on Oct 08, 2010
Here's the link to the user manual for the MPK1021:
http://www.curtisint.com/html/CustService/Manuals/CUR_MPK1021_EN.PDF
Reset of the player, by pushing the PLAY/ PAUSE together with the VOLUME +/- button.
Curtis MPK2066 ... | Answered on May 14, 2010
Possible cause:
- Look at your mp3 file naming standard paying particular attention to the suffix (eg. must have either .MP3 or .WMA for music) and overall name length (some players impose an arbitrary max length for efficiency!).
- Look at the 'properties' of your 'working' songs and those that do not appear: the songs are encoded/compressed and not all 'audio bit rates' will be supported by your specific player (128kbps fixed bit rates usually works well)
Curtis MPK2066 ... | Answered on Dec 21, 2009
your mp3 came with CD that will convert vid to file format
If you need further help, reach me via phone at https://www.6ya.com/expert/scott_541ceb86d69e7743
Curtis MPK2066 ... | Answered on Dec 06, 2009
Hello Chris,
The battery could be drained and needed to be plugged into usb to charge. In here, the computer is the one supplying power to the MP3 player so it turns on. Try charging it further like one hour before you take it off. Also, please remember that all USB devices, especially mp3 players should be "safely removed" to avoid it being fried. To safely remove, click on the green usb icon on your lower right corner of your computer and click "safely remove device..". Wait until it tell you that it is now safe to remove your usb device.
Now if it still wont work, the player might be defective and since it is still new, please dont hesitate to return back and ask for replacement as this player might give you other problems later on. Since it is under warranty it would save you further cost.
Curtis MPK2066 ... | Answered on Oct 27, 2009
It might not be able to work again depending on the extent of damage incurred. The most important thing to remember about any wet electrical/electronic device is to NEVER turn it on while there is still moisture present. It must be totally dry inside and out before turning it on. This may take several days or longer depending on ambient temperature and humidity.
Curtis MPK2066 ... | Answered on Aug 27, 2009
Try charging with switched ON position. AAlso batteries may require replacement.
Curtis MPK2066 ... | Answered on Jul 16, 2009
Files must be in MP3 format!
Curtis MPK2066 ... | Answered on Jun 28, 2009
HellO!!
Connect the player using the data cable to computer and transfer the songs to ur player,,,
Curtis MPK2066 ... | Answered on Apr 20, 2009
Remove the unit and open it up to remove disk and examine the tray drive.
Curtis Audio... | Answered on Jun 20, 2017
Curtis MPK2066  MP3 Player Logo
Popular Tags
19 questions posted
Top Curtis Audio Players & Recorders Experts
Damen Wong
Damen Wong
Steve Allison
Steve Allison
Joaquim Martins
Are you a Curtis Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Curtis Audio Players & Recorders
Most Popular Question
curtis mpk4099uk
  • Audio Players & Recorders
