20 Most Recent GE JSP57 Electric Kitchen Range Questions & Answers
I would take it apart and clean it myself. After all someone put that door together in the first place. I don't think that it would mess anything up because there isn't any electrical in the door and as long as you put it back the same way it came apart it will be just fine. Take pictures as you go so you don't forget anything along the way. Good luck!!!!
GE JSP57... | Answered on Dec 11, 2011
the self cleaning lever (that locks the door) is moved to the clean position. try moving it to clean then back to the off position and that should fix it.
Ouch. The glass top does have to be replaced but I just ran the partial model number on your range and if you're at the comp. I hope you are sitting down. Replacing it not bad. Purchasing tho is rediculous. Retail suggested price just for the top is 600.00. Rediculous pricing but GE is like that sometimes. Sorry but repairing the glass is not possible and getting it from a glass shop isn't either. Sorry for the not so good news. Rick
GE JSP57... | Answered on Mar 01, 2010
It could be a faulty motor or a faulty motor start capacitor
GE Kitchen... | Answered on Jul 11, 2019
do a search or buy universal set that are compatible
GE Kitchen... | Answered on May 29, 2019
So F71 does mean that your touchpad is failing or one of the buttons is sticking. Try to unplug the oven and use a hair dryer to heat up the touchpad. Rub the buttons with your thumb in case one of them is sticking and then let the unit cool down. Plug the oven back in and if you still get an F71 error, the only thing you can do is replace the touchpad
GE Kitchen... | Answered on May 20, 2019
Have you checked inside it? Most of my appliances have envelopes containing schematic diagrams tucked inside them at the factory.
GE Kitchen... | Answered on Apr 23, 2019
Modern ovens are much slower to preheat than older models. In some cases it is because they only use the bake (lower) element, while the older units used both the bake and the grill (upper) elements to preheat. If this is a new condition of your oven, check for malfunctioning oven element(s). A loose or intermittently non-functioning element will create a slow heat-up.
GE Kitchen... | Answered on Apr 20, 2019
GE JSP57 Electric Kitchen Range Logo
Popular Tags
11 questions posted
Top Kitchen Ranges Experts
Ismael Rodriguez...
Steve Allison
Steve Allison
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
View Most Popular
GE Kitchen Ranges
  • GE Kitchen Ranges
Most Popular Question
broken glass cooktop
  • Kitchen Ranges
