I get an "SA" error message when the oven get's too hot I guess. Any clue to what can be...
(More)
I get an "SA" error message when the oven get's too hot I guess. Any clue to what can be the problem?
Hi, We have a GE Model JBP95 electric range (self cleaning & ceramic cook top). Just after...
(More)
Hi, We have a GE Model JBP95 electric range (self cleaning & ceramic cook top). Just after a cleaning cycle, we found that one of the two small sheet metal screws (3/16" dia self tapping screw) that hold the oven vent fixture in place, inside the oven, had fallen out. On closer examination, I discovered that the oven liner had corroded where the screw was inserted, it had left a 17/64" hole. The oven is vented through a round ceramic piece, possibly a flame arrester(?), that was held in place by two 3/16" screws. The range is in excellent condition, I was surprised to find corrosion. I want to replace the fastener to plug the small hole that now exists in the top of the oven, and want to avoid risk of anything else falling into food. Problem is that the metal of the oven liner may be thin at that spot, and would require either a large self tapping screw or access to the top of the oven liner to install a stainless nut and screw that would be the best fix. What do you recommend?
Recently told that we should not use the self cleaning. This is the 2nd time in 7 yrs that the...
(More)
Recently told that we should not use the self cleaning. This is the 2nd time in 7 yrs that the heating coil has caught on fire and burned out. Had to have someone come and replace the first coil and was costly. Please advise. Can not use the oven again.
When I turn on my electic oven, the digital number change quickly up and down and up..so I'm note...
(More)
When I turn on my electic oven, the digital number change quickly up and down and up..so I'm note sure if it is working correctly! Is it a thermastat or heating element or what?
It seems to take forever for our oven to heat up. Heats up faster on convection than on bake, but is...
(More)
It seems to take forever for our oven to heat up. Heats up faster on convection than on bake, but is still quite slow (maybe 30 minutes to 400 or 450?). Sometimes it seems it just won't get there. Only other oddity is a difference in temperature when the oven is on bake or convection - about right on on convection, and 25 degrees too cool on bake. And from reading other responses, I don't seem to have any bottom element. Model JBP95BF1BB
While trying to set the temperature on the stove, a flashing "F3" shows up on the control...
(More)
While trying to set the temperature on the stove, a flashing "F3" shows up on the control panel. What does it meand and how do I fix it?
This advice is for GAS ovens with glow bar type
igniters. This is a fairly simple repair
that MOST do-it-yourselfers can accomplish with just a...
written by jsrock516
This advice is for Electric Ranges equipped with glass smooth tops. If it becomes necessary to replace the cook top due to wear or damage, here's some...
Here is a useful tip in identifying a frequently reported problem on some model ranges and wall ovens equipped with an Electronic Range Control (ERC)...
This "high end...?' range blew up twice early on when using the oven. My wife had her hair and eyebrows burned just by opening the oven door to...
written by skywagon185
As oven probes age, they can sometimes generate error codes on kitchen ranges and render them inoperative. The error code varies between models, but...
This advice is on how to replace a bad element on kitchen ranges that utilize ELECTRIC heating elements for baking and broiling. 1. UNPLUG the range...
Honest, Dependable, Available & Professional!
Appliance Parts Supply! We Ship Nationwide. Our Phones Answered From 7 AM - 9 PM CST Mon - Sat.
Over 30 Years Experience!
972-859-0929 - Call us NOW!
www.accurate-appliance-service.com
