FixYa.com
GE JGBP32WEFWW Gas Kitchen Range
All Products > GE > Kitchen Ranges
Problems with GE JGBP32WEFWW Gas Kitchen Range?
Search inside GE JGBP32WEFWW Gas Kitchen Range Knowledgebase
Troubleshooting and Support
Solved Problems for GE JGBP32WEFWW Gas Kitchen Range RSS Feed Post a New Problem
GAS STOVE PROBLEM WITH OVEN ON...
WHEN OVEN IS ON "BAKE", IT WILL NOT GO OVER 100 DEGREES AND A LIGHT THAT SAYS "ON" COMES ON AND WILL...
1 Solution
Hello, ARe you able to tell
Hello, ARe you able to tell me where I can buy the rubber beading that goes around the sharp edges of the glass, that...
1 Solution
After 2.5 years and approc
After 2.5 years and approc 10 uses the bottom element in the oven went out. Is this an expensive item to replace or can...
1 Solution
Thermador RED30VRS Electric Range Oven...
The 120V is present at the bake element (both sides). The element resistance is 21 ohms. Thinking that there may be an...
1 Solution
oven does not heat
oven does not heat
1 Solution
two left burners on gas
two left burners on gas stove won't light without a match. Two on the right will. Sherry
1 Solution
I have a Westinghouse stove
I have a Westinghouse stove Model PAD501R20 about 10 years old. The left, rear coil has blown & I have no idea...
Post a Solution
View All
Unsolved Support Problems
Unsolved Problems for GE JGBP32WEFWW Gas Kitchen Range RSS Feed Post a New Problem
oven [bake & broil will not work]
once the oven temp is set igniters either one will not glow,,nothing comes on,,nor the oven clean mode. last time we had...
Post a Solution
Ran Clean cycle. Now oven won't heat
I ran the clean cycle on the oven. I turned the oven on the next day. and the Clean light comes on and flashes, and not...
Post a Solution
Tips & Tricks
Post a New Tip
Specifications
Key Features
Fuel TypeGas
Element TypeBurner
No. of Cooking Elements4 Elements
Oven AmountSingle
Self CleaningWith Self Cleaning
Other Features
Convection TypeWith Convection
Oven FunctionalityBake · Roast · Broil
Sabbath ModeWith Sabbath Mode
Dimensions
Overall Depth28.25 in.
Overall Height46.5 in.
Overall Width30 in.
Warranty
Warranty1 Year
GE Contact Information
Main support number1-800-626-2005
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
