20 Most Recent Samsung PS50A457 50 in. Plasma TV Questions & Answers
Make sure it is plugged into a working outlet with the correct power adapter. Also try turning it on with the buttons on the tv rather than the remote, as the batteries in the remote may have died.
Samsung PS50A457... | Answered on Aug 04, 2013
hi can i just add? I have recently got this tv but for some reason when i set setting to Normal they reset to dynamic?? After about twenty mins? I keep having to change back to normal or if i set it to perfect brightness etc... it just goes back to dynamic again? i.e cell light 100% and contrast up to 100%!
Why is this??
Samsung PS50A457... | Answered on Jan 13, 2013
my 50 inch samsung is 4 years old. a black line has appeared just off centre screen. the line is approx.an inch wide and runs from top to bottom. can it be repaired?
Samsung PS50A457... | Answered on Dec 06, 2012
Have you tried to go into your initial start up settings to verify that under source you have it set to cable and not antenna? you can also reference this Samsung repair sheet for any addiitonal questions. We are a Samsung Plasma TV COD repair center in Denver, Colorado
Samsung PS50A457... | Answered on Jun 02, 2012
hi there.
unfortunately,its most likely a faulty screen,this is a common symptom with most plasma screen failures...
regards,steve
Samsung PS50A457... | Answered on Oct 22, 2010
Yes,all HDTVS work with the sky 3d.
Samsung PS50A457... | Answered on May 21, 2010
is inverter board defective or power supply dead
Samsung PS50A457... | Answered on Feb 20, 2010
Possibly could be the Y buffers --if the are next to each other could be a bad connection on a ribbon cable ---you need to call for service
Samsung PS50A457... | Answered on Feb 06, 2010
If you talking about on one screen, you cant. BUT you can buy a TV card for your computer so that it will have a built in TV. so you can theoretically have split screen TV and computer. But what your thinking off only works on 2 or more player games consoles
Samsung PS50A457... | Answered on Nov 30, 2009
Not unless you are using a regular antenna and dont have a TV with a digital tunner.
Samsung PS50A457... | Answered on Sep 29, 2009
Match the PS3's output resolution to your TVs (in this case 720p).
Don't sit too close, otherwise you'll start to see individual pixels.
Make sure the HDMI cable is good quality.
As for picture settings, they will very so much according to the viewing conditions that i cannot give you settings that are gauranteed to work for you. But sharpness should always be 0 when dealing with HD content.
If you want to really get the best picture from your TV, try using a THX disc to calibrate it. Luckily these are normally included on Disney PIXAR DVDs, so go find yourself a copy of CARS or something. Follow the instructions of the THX setup, and you should have youself a sweet looking picture in no time.
Hope this Helps.
Samsung PS50A457... | Answered on Apr 28, 2009
The applicable code will be found in your Newstar remote control, if it is compatible.
Samsung... | Answered 37 minutes ago
Use code search to find it. If a search through all codes stored in the URC fails, try a different one.
Samsung... | Answered 41 minutes ago
Samsung PS50A457 50 in. Plasma TV Logo
34 questions posted
Jerry Greenberg
Jerry Greenberg
Ekse
View Most Popular
  • Samsung Televison & Video
Most Popular Question
get cable
  • Televison & Video
