20 Most Recent
LG 26LH20 LCD TV Questions & Answers
My LG 26LH20 turns itseld
Tv turn itself off after 2-3 seconds the tv still audio voices?Yes,than the tv long board that call the LCD inverter board it is dead.Require change the tv long LCD inverter board,this board help the LCD screen panel to have a backlight to produced a picture or 2-3 seconds tv power died completely no power to tv all?Yes,than this problems the tv power supply board it is dying.That the board where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish long LCD inverter board or the tv power supply board for the replacement.
The volume doesn't go high
hello. use the remote. go into the menu and find the audio section. once in there adjust the audio to max and then control it with the remote. j.
How do i connect aiwa speakers with 26
LG does not have direct speaker connectors. You will have to use the audio out RCA jacks on the set through RCA cables into a seperate amplifier. Hope this helps.
I have a LG dvd
player 5083 inserted the disc the correct way into the draw but the machine does not play the disc a very slight humming noise is heard then it spits the drawer back out
Clean the Lens: Use a DVD cleaning disc to clean the lens. If the problem persists, consider professional cleaning.
Test Other Discs: Try playing different DVDs to see if the issue occurs consistently. If it's specific to one disc, that disc might be the problem.
Check for Updates: Make sure your DVD player's firmware is updated. Refer to the manufacturer's instructions for firmware updates.
Try a Different TV: Connect your DVD player to a different TV to see if the noise disappears. If it does, the issue might be with your TV.
The hum is simply the player trying to read the disc. It can't so, it spits it out.
Remember that prolonged use of a malfunctioning DVD player could potentially cause damage. If the problem persists, consider seeking professional repair or replacement
