ge jbp26g...my bottom bake element burned out & i bought a new one. having turned the...
(More)
GE JBP26G...my bottom bake element burned out & I bought a new one. Having turned the breaker off, the oven was dark during removal of old. Consequently, we didn't know how to reattach new element to the 3 wires..two black and one yellow. We attached a black on left, a yellow on right..tried the oven on warm to see if it worked and it did. Not knowing if the 3rd and remaining black wire was a ground? we left the job until this morning. I turned the breaker back on to heat pancakes on the surface and later I simply moved the bottom burner (while off but breaker on) an inch to tell someone on the phone where I had hooked up the two wires and the area where the wires were sparked and blew out the oven. The breaker was still on so now I am assuming I blew a breaker in the oven itself..and I don't know how to proceed.
Yesterday I set the oven to preheat to 325 and in a few minutes the "ON" light went out...
(More)
Yesterday I set the oven to preheat to 325 and in a few minutes the "ON" light went out but the "PREHEAT" light was blinking and beeping. I looked into the oven and the broiler element was BRIGHT !!! RED and the lower element was off (as best as I could tell). Nothing I did at the range would turn the element off and the whole range was getting EXTREMELY hot by then. I threw the breaker. My husband has removed the elements, but they really don't look bad??? Can't find the manual as this is a 1998 model...any help???
The dual heating element on my Kemore glass top radiant range is not working. How to fix this...
(More)
The dual heating element on my Kemore glass top radiant range is not working. How to fix this myself?
We have a glass top stove with a "touch spot" to switch on the outer coil of the largest...
(More)
We have a glass top stove with a "touch spot" to switch on the outer coil of the largest heating element(lower left). The touch spot only recognizes when you touch it 5% of the time and even when you succeed in getting it to turn on, it only stays on for 5-35 seconds.
magic chef range burners will not heat. Only the clock is on. The broiler and oven elements do not...
(More)
magic chef range burners will not heat. Only the clock is on. The broiler and oven elements do not come on either. There used to be a buzz sound when we turned on the burners or oven and then they would start to heat up. Now there is no buzz and no heating at all
This advice is for GAS ovens with glow bar type
igniters. This is a fairly simple repair
that MOST do-it-yourselfers can accomplish with just a...
written by jsrock516
This advice is for Electric Ranges equipped with glass smooth tops. If it becomes necessary to replace the cook top due to wear or damage, here's some...
Here is a useful tip in identifying a frequently reported problem on some model ranges and wall ovens equipped with an Electronic Range Control (ERC)...
This "high end...?' range blew up twice early on when using the oven. My wife had her hair and eyebrows burned just by opening the oven door to...
written by skywagon185
As oven probes age, they can sometimes generate error codes on kitchen ranges and render them inoperative. The error code varies between models, but...
This advice is on how to replace a bad element on kitchen ranges that utilize ELECTRIC heating elements for baking and broiling. 1. UNPLUG the range...
Honest, Dependable, Available & Professional!
Appliance Parts Supply! We Ship Nationwide. Our Phones Answered From 7 AM - 9 PM CST Mon - Sat.
Over 30 Years Experience!
972-859-0929 - Call us NOW!
www.accurate-appliance-service.com
