Pabaaar
hello,
Go to "gallery.mobile9.com/c/240-320-mobile-java-games/"
and download games
you should also download the small application that convert the jar file
into jad that is called jadmaker, that i use. you can find it here
"download.com/JADMaker/3000-2213_4-10725641.html?cdlPid=10725640"
then you open the the jadmaker, then you drag the download games or
application into the jadmaker, you'll see that it will create the jad
file on the directory.
connect your samsung g400, then select media player from the connection
type.
open the folder, then open phone, then create a directory and name it
game or you may still let it as new folder, that doesn't matter.
copy the two files, the jar one and the jad one to the new folder you
have just created on your phone.
(step 1)
then you press *#6984125*#, then select the internals then press
*#9072641*# then select storage settings.
(step 2)
in the storage settings select "1.update media database", after that
"2.update java db", then select "7.update app database" and lastly
select the "8.create Ax Dat file"
OK....now you'll just done one quarter of the process, i have named step
1 and step 2 because it will be used....OK.
then close that storage settings, by pressing on the cancel button (off
one or cancel a call)
then go to "My Files" from "Menu" then go to the end, you'll see a new
folder named "new folder", just delete it.
then restart the step 1 and 2
when you've finished, close the storage settings again then restart your
mobile, then again restart the step 1 and 2.
when you've finished with it, then go to "my files" then go to "games
and more", if you've done it well, you'll see the icon of your games
into it...you can start enjoying then.
add 2-3 games dont add more it will not work.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
thank you for using fixya have a nice day:-)
