20 Most Recent
Samsung OmniaHD i8910 Smartphone Questions & Answers
Do not connect to pc
PC studio(PC suit) fo Samsung OmniaHD i8910
you can download here- http://download.famouswhy.com/samsung_pc_studio/free_download.html
1. Download the Samsung PC studio .
2. Double click the exe file to run it.
3. Follow the instructions given to you.
4. When installation has completed, the program will open and you can connect your Samsung OmniaHD i8910
without any problem.
Good Luck.
Thanks for using FixYa.
My son forgot the code of his samsung omnia hd i8910 1 want to reset the settings but i cant because of that code
- Open the telep
*2767*3855# - Factory reset hone dialler by pressing the software button on the bottom left of the front screen.
- Type *#7370#
- You'll be asked if you want to restore all of the original settings and warned that the phone will restart. Choose yes.
- Now you'll be asked to enter the lock code. Enter 00000000 as the code. That's eight zeros.
- Click the OK button and the phone will reset. This takes some time so be patient.
Occasionally you'll find yourself in a situation where you can't use the screen and therefore can't use this process to reformat a phone. In that case you'll need to do the following.- Pull the battery to make sure it's powered off correctly then replace it.
- Hold down the green call button and the middle button at the same time.
- With those two buttons held down, press the red power on button.
- The phone should give you the option to format now and you can press the green key to accept it.
Be aware that the phone memory and the hard drive will all be wiped clean so back up anything you need to keep either to a PC or to a memory card. Don't forget to remove the memory card before the reset as some memory cards may also be occasionally wiped in this process.
Forgot the code how can i reset it
- Open the telephone dialler by pressing the software button on the bottom left of the front screen
- Type *#7370#
- Be aware that the phone memory, the hard drive and any inserted memory cards will all be wiped clean so back up anything you need to keep either to a PC or to a memory card (don't forget to remove the memory card before the reset).
REVIVE A DEAD SAMSUNG I8910
have you tried to attach to computer and use the phone app to see if it can reload os on the phone.did anything take place that you believe might have caused this?
