20 Most Recent GE JGBS20 Gas Kitchen Range Questions & Answers
Yes, most likely the broil relay got welded shut. The company will want to sell you a whole new control board for about $200.00 -- but if you have any soldering skills, you can purchase a new replay for around $6.50.
GE JGBS20 Gas... | Answered on Feb 17, 2018
Hi the problem here is the igniter. Take the floor of the oven out and then the flame spreader. The igniter will be located at the back of the burner. Set the oven for 350, if the igniter does not light then test it with an ohms meter it should read continuity. If it reads open you should replace it. If the igniter does glow it still could be bad, the igniter should glow bright yellow to the point you can't look at it. If the igniter glows orange/yellow it is bad you will need to replace it. If you have any other questions please feel free to comment. Mike
GE JGBS20 Gas... | Answered on Jan 26, 2013
Here is a tip that I wrote that will help you with that problem...
The ignitor for your burner has faied...
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
GE JGBS20 Gas... | Answered on Apr 18, 2010
The easiest way to check if the gas side is working would be to check if the stove burners are working.
You did not mention why you replaced the ignitor.
Some good tips re the oven ignitor systems is available at
http://www.appliance411.com/links/jump.cgi?ID=823
scroll down to the glow ignitors.
Looking forward to your comments. I am assuming you have got a user manual for this unit. just in case it is available at
http://dl.owneriq.net/d/d4600872-6c69-4c4c-b3f3-f1ba6405f4f4.pdf
GE JGBS20 Gas... | Answered on Feb 13, 2010
clean pilot assembly. then oven thermostat
GE JGBS20 Gas... | Answered on Jan 02, 2010
its electronically ignited turn the switch on and it should auto ignite
GE JGBS20 Gas... | Answered on Nov 04, 2009
your model is not complete so i am sending you a breakdown of a JGBS20 gas range. there should be more to the model and you can usually find it on the frame of the stove after opening the oven drawer. anyway, the igniter is #218 in the picture. maybe it will help you somewhat to figure out what needs to come off to change it. hope this helps.250
GE JGBS20 Gas... | Answered on Oct 24, 2009
What you found is the bulb for the thermostat which has broken off. The model number you supply is incomplete. If you have the full model number, I can get you a part number.
GE JGBS20 Gas... | Answered on Apr 10, 2009
It could be a faulty motor or a faulty motor start capacitor
GE Kitchen... | Answered on Jul 11, 2019
GE JGBS20 Gas Kitchen Range Logo
22 questions posted
Top Kitchen Ranges Experts
Ismael Rodriguez...
Steve Allison
Steve Allison
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
View Most Popular
GE Kitchen Ranges
  • GE Kitchen Ranges
Most Popular Question
gas oven not lighting
  • Kitchen Ranges
