20 Most Recent Cadet Manufacturing CADET Softheat Portable Hydronic Baseboard Heater 1500 Watts 120 Volts 72 (EPA1500/3W) 13169 Questions & Answers
I agree with the glycol solution but u want to change it every yr if portable
Cadet... | Answered on Jan 19, 2015
is this for a boiler system
hi the heaters are some times filled with glycol which may be what you have , you can look this up on google and see what is in it
Cadet... | Answered on Mar 08, 2010
If its a one story house, the system pressure should be somewhere around 10 to 12 psi. There should be a PRV (pressure reducing valve) on the domestic water line supplying make up water to the boiler. The shut off valve in that line should be in the open position unless the prv leaks through and slowly overpressurizes your system to the point of tripping the pop-off valve. If so, then the manual shut off should be kept closed then opened only to boost the pressure up a bit in the system. It kinda sounds like you are suffering from low system pressure.
If there is a vent or vents in the system, try bleeding them into a coffee cup and you may find it sputtering air/water mixture. Bleed them until you have full water flow and make sure you keep approximately 10 psi in the system.
Cadet... | Answered on Dec 30, 2014
There is a little sensor called a 'flame sensor' that is inserted into the actual flame. Its only job is to complete a grounding circuit on the control board actually through the gas flame... By the description of your problem, it sounds like it either has oxidation on its surface OR the physical connections at the flame sensor itself or where it plugs into the control board have just enough oxidation to imhibit the signal from the flame sensor.
I would suggest calling the service center to have a tech look at it.
Heating & Cooling Logo
Popular Tags
9 questions posted
Top Cadet Manufacturing Heating & Cooling Experts
Paul Carew
Donni Steen
Marvin
Marvin
Are you a Cadet Manufacturing Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Cadet Manufacturing Heating & Cooling
Most Popular Question
will glycol solution in cadet softheat
  • Heating & Cooling
