FixYa.com
GE JBP69 Electric Kitchen Range
All Products > GE > Kitchen Ranges
Problems with GE JBP69 Electric Kitchen Range?
Troubleshooting and Support
Solved Problems for GE JBP69 Electric Kitchen Range RSS Feed Post a New Problem
electronic control pad
The timer feature on the control pad has become increasingly difficult to use because the ?plus? pad does not respond...
1 Solution
Range top won't heat
Light comes on when you turn stove top on but doesn't heat. Oven will only come on when range top light is on
1 Solution
GE OVEN DOES NOT WORK PROPERLY JBP69SGH2SS
When baking, the oven preheats without any problems then after around 10+ (time varies) the oven stops heating. The...
1 Solution
Oven does not light
When I turn on the oven, the display goes to PrE (preheat mode) but the oven does not heat up. The ceramic igniters are...
1 Solution
oven and clock inop
on the display there is one red dot that is all. the clock and oven is inop. thank you for your help in advance.Roy...
1 Solution
oven not working properly
Everthing about the range seems to be working properly, except the oven. When turned on, the burners do not produce a...
1 Solution
My surface element has to be...
My surface element has to be "jiggled" or pushed in to make it work....what may be wrong ?
1 Solution
View All
Unsolved Support Problems
Unsolved Problems for GE JBP69 Electric Kitchen Range RSS Feed Post a New Problem
Kitchen Aid superba (electric oven)
Oven doesn't come on. Light indicators are all fine but the oven elements (top &bottom) don't kick in
Post a Solution
oven dont turn on
i have a ge spectra electic oven it wont turn on the time just flash and when you turn the oven on the oven light just...
Post a Solution
control panel
the control panel on our new Ge profile get really hot while running the oven
Post a Solution
Tips & Tricks
Post a New Tip
Specifications
Key Features
Fuel TypeElectric
Element TypeSolid
No. of Cooking Elements4 Elements
Oven AmountSingle
Self CleaningWith Self Cleaning
Other Features
Capacity5 cu. ft.
Convection TypeWith Convection
Oven FunctionalityBake · Roast · Broil
Sabbath ModeNo Sabbath Mode
Dimensions
Overall Depth25.5 in.
Overall Height47 in.
Overall Width30 in.
GE Contact Information
Main support number1-800-626-2005
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
