I have a GE JBP66BB1WH Electric Range. I cleaned it, the following day went to use the oven, and...
(More)
I have a GE JBP66BB1WH Electric Range. I cleaned it, the following day went to use the oven, and when I turn the oven on, the "clean" light comes on, and the oven doesn't work.
I have a jbp66g stove by GE. The top elements work but the control panel is blank with no power and...
(More)
I have a jbp66g stove by GE. The top elements work but the control panel is blank with no power and the oven doesn't work. The oven light also doesn't work. I have changed the control/display panel and still have the same issue. Any help much appreciated.
when I attempt to preheat my GE oven, I get an F5 error message flashing on the display and beeping...
(More)
when I attempt to preheat my GE oven, I get an F5 error message flashing on the display and beeping then it turns itself off - Help?!?!
my front burner exploded after i turned it on. It seemed like it was an electrical energy ball that...
(More)
my front burner exploded after i turned it on. It seemed like it was an electrical energy ball that came up off the burner coil. It was making a buzzing noise like power lines make when the energy arcs.
Everything works except the oven. It will go through the clean function & heat normally, but...
(More)
Everything works except the oven. It will go through the clean function & heat normally, but when I try to use the oven in any other fashion it will not heat.Is there a reset for this model?
JBP66 range. My wife used the self-cleaning feature a few days ago, and now the oven part of the...
(More)
JBP66 range. My wife used the self-cleaning feature a few days ago, and now the oven part of the range will not come on. The 'clean' light flashes but no temp will register and the unit barely heats up. We have redone the cleaning cycle again to see if that would fix it - it again self-cleaned properly, but still will not bake or broil. I have unplugged the unit to try and reset the circuit board. Its in great shape; any idea what may have gone wrong? Replacement part recommendations? Is the CPU in this range a handy-man plug-n-play swap or something more serious that will get me into trouble...
This advice is for GAS ovens with glow bar type
igniters. This is a fairly simple repair
that MOST do-it-yourselfers can accomplish with just a...
written by jsrock516
This advice is for Electric Ranges equipped with glass smooth tops. If it becomes necessary to replace the cook top due to wear or damage, here's some...
Here is a useful tip in identifying a frequently reported problem on some model ranges and wall ovens equipped with an Electronic Range Control (ERC)...
This "high end...?' range blew up twice early on when using the oven. My wife had her hair and eyebrows burned just by opening the oven door to...
written by skywagon185
As oven probes age, they can sometimes generate error codes on kitchen ranges and render them inoperative. The error code varies between models, but...
This advice is on how to replace a bad element on kitchen ranges that utilize ELECTRIC heating elements for baking and broiling. 1. UNPLUG the range...
Honest, Dependable, Available & Professional!
Appliance Parts Supply! We Ship Nationwide. Our Phones Answered From 7 AM - 9 PM CST Mon - Sat.
Over 30 Years Experience!
972-859-0929 - Call us NOW!
www.accurate-appliance-service.com
