20 Most Recent Dayton G73 Utility Heater Questions & Answers
Yes you can move thermostat wherever you want but remember if not placed at a suitable location space may either be too hot or too cold .For example if you put it too close to the heater it will satisfy faster without allowing the whole space to warm up
Dayton G73... | Answered on Mar 07, 2018
Where can i find a thermostat atc-26b l57c 5813-11002-00 for my Dayton g73 heater. Any help would be appreciated. Can find anything info of course lol
Dayton G73... | Answered on Jan 18, 2017
remove thermostat wires off the unit heater and if it stops running you have the red and white wires tuching somewhere in the wire,ore bad thermotat.
Dayton G73... | Answered on Oct 30, 2013
who told you air pump is supposed to be 5 psi? at the desatech site in their PDF troubleshooting guide air supposed to be 3.0-3.5 psi.
Dayton G73... | Answered on Jan 21, 2012
check the flue for a restriction, and check the flame sensor and clean with steel wool, it is in the burner compartment.
Dayton G73... | Answered on Dec 01, 2011
have you clean it ? put a vac on blow and blow the dust out of it could just be blocked with dust , works some times could be that simple
Dayton G73... | Answered on Feb 09, 2011
You will need to replace the thermostat in the heater. Also, check for any dust and dirt buildup in the unit. Here is a link for the part for your heater.
Dayton G73... | Answered on Feb 07, 2011
Not usually but it could...
It is more likely that there was and is a poor connection there...
Strip back the wire and reconnect it making sure that the connection is a very tight good one...
heatman101
Dayton G73... | Answered on Jan 16, 2011
No I would not think so, a thermostat is only to turn the heater on and off period. Now inside the heater there are controls that set when the blower is to come on usually set at 150 degrees and another to cool down the furnace and this is usually around 130 to 120 degrees. Again these tell it when to run and when to shut down, internally they call them high and low limit controls. I would try to locate the lower limit and boost the cool down temperature up to take care of this problem.
Dayton G73... | Answered on Dec 27, 2010
it depends what u have the tstat set on butat 20 degrees it should not turn off at all does it have a wall tstat if so take the cover off an u should have 2 wires a red and a white tie them together and see if it stays on if it does then its the thermostat if not then u have another problem but it sounds like its the thermostat
Dayton G73... | Answered on Feb 26, 2010
Themostat will be at fault for not shutting this off .. If two weeks old what kind of warranty was given?
Dayton G73... | Answered on Feb 02, 2010
Do you hear a click when you turn thermostat all the way up? If this is a
220volt unit, then the contactor is porbably not pulled in. One sure way
to make sure you have power and functions is to have a electrically inclined person push the contactor in, unit shouldrun
Dayton G73... | Answered on Jan 31, 2010
Around oklahoma, dirt dobber nests freezes up every things. Eyeball this and oil all frozen parts.
I WOULD TRY TO BYPASS THE THERMOSTAT TO MAKE SURE THE UNIT WORKS AND REPLACE THE THERMOSTAT IF IT DOES , SEE IF IT IS UNDER WARRENTY, MY GUESS WOULD BE THAT IT IS JUST DEFFECTIVE, AND YOU ARE TRYING TO FIND A CAUSE, THIER IS NO REAL CAUSE THAT I CAN THINK OF THAT WOULD BURN UP THE THERMOSTAT IF IT WAS OR HAS BEEN WORKING, GOOD LUCK
Dayton G73... | Answered on Jan 27, 2010
Are you getting 240 volts to the heater? The heater should react to thermostat instantly.
Dayton G73... | Answered on Jan 18, 2010
You just got it, you have a defective thermostat, and it
needs to be replaced to get it working normally. Hope this help you.
Dayton G73... | Answered on Jan 08, 2010
Dayton G73 Utility Heater Logo
54 questions posted
Top Dayton Heating & Cooling Experts
Paul Carew
Craig Butler
Craig Butler
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Dayton Heating & Cooling
Most Popular Question
dayton heater older model just
  • Heating & Cooling
