20 Most Recent GE GSS22VGMCC / GSS22VGMWW Side by Side Refrigerator Questions & Answers
The HC95DA700 capacitor is a start capacitor that is used in conjunction with the relay to get the compressor started. Then the relay takes the start cap out of the circuit and the run cap takes over. It could be any of the three components is bad. I usually change all three to be sure. If that doesn't work the compressor is locked up and, in that case, you have to replace the compressor.
GE Refrigerators | Answered on Sep 05, 2019
I had the same problem. The cause is the digital display is not communicating with the motherboard. What had happened in my case is the plug connection between the door's digital display and the motherboard had become unplugged. The wire running from the motherboard runs below the fridge, and connects via plug located along the bottom of the fridge below the freezer door, connecting to the wire running from the display to the bottom of the freezer door. I just reconnected it and that reset the display. Glad for it too, I thought I needed a new $130 motherboard! Hope this helped!
GE Refrigerators | Answered on Aug 29, 2019
look up in to the area of ice flap no screws grab with hands at bottom pull up and out remove 4 screws for ice funnel replace flap
GE Refrigerators | Answered on Aug 28, 2019
Tip
Refrigerator Ice Dispenser Not Working
After about 1 year of usage, ice dispenser panel stops working. Just unplug and plug back after 1 minute (thinking about reboot of PC). Panel starts blinking about 15 hours (be patient!) though the compressor starts working again. Be patient on blinking!
i guess the control board stuck/hung up something on my case. Good luck!
on Aug 26, 2019 | GE Refrigerators
look up on line or if ordering just ask for damper for you make and model but most sale sites have a break down of all parts
GE Refrigerators | Answered on Aug 25, 2019
First check to see if the condenser coils are clean and that the fan is running?
if they are okay
Call an engineer. You have a gas leak and that needs fixing before topping up.
GE Refrigerators | Answered on Aug 01, 2019
GE GSS22VGMCC / GSS22VGMWW Side by Side Refrigerator Logo
Popular Tags
2 questions posted
Top Refrigerators Experts
Brad Goodale
Matt Sicignano
Level 1 Expert
JP Meneide
JP Meneide
View Most Popular
GE Refrigerators
  • GE Refrigerators
Most Popular Question
carrier 38tdb048300 air conditioner
  • Refrigerators
