Dimplex DS5598 Mid-Size Heater
Problems with Dimplex DS5598 Mid-Size Heater?
Ask our Experts
Chat with a Pro
Tell us why
Share your Experience
Do you recommend the
Problems
& Solutions
Manuals
& Guides
Repair
Service
Reviews
& Ratings
Warranty
& Spec
Troubleshooting and Support
Solved Problems for Dimplex DS5598 Mid-Size Heater RSS Feed
Click here to get instant support from our best Experts!
View More Results for Dimplex DS5598 Mid-Size Heater
Questions and Unsolved Support Problems
Unsolved Problems for Dimplex DS5598 Mid-Size Heater RSS Feed
Answer
Hi I have a Dimplex model HTN20 electric fan heater, the fan heater has never worked properly, when... (More)
Answer
We plugged in our Dimplex ds3311 fireplace and it is not working at all. Any suggestions would be a... (More)
Answer
The stove will not keep running I think the problem is the thermostat
Answer
I have a Dimplex heater like pictured that needs an RH switch. It is the first one that needs to be... (More)
Answer
Have a cat. no. DS5598 Mod C heater that blows warm air for just a few minutes then blows cool air,... (More)
Answer
main power switch broken- need a replacement part
Find a Manual
Dimplex DS5598 Mid-Size Heater Manuals & Guides
Sorry. We do not have a manual for this product.
You can...
  • Search for manuals of related products.
  • Ask an Expert to find it!
Tips & Tricks
(Post a New Tip)
Geothermal Heat Pumps And Radiant Heating - An Absolutely Fabulous...
Geothermal Heat Pumps are usually associated with hot air heating and air conditioning. In climates that very seldom need air conditioning you need to... written by heatman101
Oil Burner Problems Can Sometimes be Fixed with a TigerLoop
There are sometimes that an oil burner problem fix is much easier than you would think. Often overlooked is a device that will not only fix many air... written by heatman101
Heater check out list for heater failures
Almost all furnaces built after 1978 have intermittant type pilots. Ca banned them requiring electronic spark or hot surface ignitors, followed by... written by kdgrayson
Furnace issues? Read this first!
Many furnace troubles can be attributed to a dirty air filter. A dirty filter makes the convection air blower work harder than normal increasing the... written by Therinnaiguy
Gas Furnace Troubleshooting With an Electric Meter
The gas furnace is on the blink and you need to figure out what is the reason why the heater isn?t heating. Grab your electric... written by heatman101
How to Hookup Your Outdoor Wood Boiler to Your Existing Heating System
You just bought or a thinking of buying an outdoor wood boiler. How do you integrate that boiler into your existing home heating system? The... written by heatman101
Gas Furnace Repair - Steps to Troubleshoot the Problem Yourself
Your gas furnace is not heating. You know that is has power because the lights are blinking showing you some kind of weird code. But it... written by heatman101
Beckett Oil Burner Problems What to do if you run Out of Fuel Oil
Running out of heating oil is not all that uncommon. There are many things that can go wrong causing you to run out. When this happens do not panic,... written by heatman101
WikiManual
(Post a New Chapter)
Be the first to Post a New Chapter
Upload Manuals
I need help with
near zipcode:
Please enter your zipcode
Search
Top Repair Providers for DS5598 Mid-Size Heater
Nationwide | 8009059506 | Website
Traditional water heaters use a storage tank to hol... Read More
Featured Listing
Nationwide | 8884489872 | Website
Nationwide plumbers where ever you need us any tim... Read More
Featured Listing
Nationwide | 866 3278928
Rate and Review the Dimplex DS5598 Mid-Size Heater
Write a review:
Rate this product:
Would you recommend the DS5598 Mid-Size Heater to your friends and family?
Is it reliable?
Is it easy to use?
Is it a good value?
Find a Warranty
Specifications for Dimplex DS5598 Mid-Size Heater
Key Features
Type
Mid-Size
Features
Thermostat
Power Source
Electric
Fan Forced
Fan Forced
Power
Power
1,500 Watt
BTU
5,115 BTU
Dimensions
Depth
15.5 in.
Height
25.9 in.
Width
23.8 in.
Weight
70 lb.
Warranty
Warranty
1 Year
Describe your problem:
Top Heaters Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
