20 Most Recent Pentair IntelliFlo i1 Variable Speed Pool Pump 011008 Questions & Answers
make sure to set the time if its not set already
Pentair... | Answered on Nov 20, 2015
check gas pressure and check to see if burner tubes clogged also check internal bypass in header spring might be bad unit is over heating that's why fusible link went bad
Pentair Pool &... | Answered on Aug 26, 2018
check the roll out switch! or make sure your filters are clean if not those could be a flow switch!
Pentair Pool &... | Answered on Aug 04, 2018
I would test for leakage first with a megger.
if in set up see if you can name them numbers 1 thru 4 to identify them or possible dip switches to identify
Pentair Pool &... | Answered on Jul 25, 2018
possible leak in heat exchange and water ruined ignitor
Pentair Pool &... | Answered on Jul 08, 2018
you need only apply small amount of lube between thumb and forefinger and turn o ring clockwise to apply lube to it. do not over lube o rings they may not seal. You may have to take pump apart and remove all excess lube. Also check for obstruction in discharge line you may also tighten band
Pentair Pool &... | Answered on Jun 26, 2018
Pentair IntelliFlo i1 Variable Speed Pool Pump 011008 Logo
1 questions posted
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
View Most Popular
Pentair Pool & Spa
  • Pentair Pool & Spa
Most Popular Question
review existing pump start stop times
  • Pool & Spa
