20 Most Recent Black and Decker USA Black & Decker FP2500B PowerPro Food Processor Refurbished BLACK Questions & Answers
2answers
What is a meat tenderizer?
This is used to tenderize meat before you cook it. It makes the meat easier to chew and digest. You can also use it before you boil or fry meat. You can do this mechanically, with something like a meat mallet that cuts up the meat fibres. You can do it thermally by putting the temperature really high to break down the connective tissue of the meat. The last method is enzymatic and uses enzymes to break down the collagen. This method is either slow with dry-aging the meat or you can use fruit to marinate the meat.
4/16/2024 6:28:01 AM • Home • Answered 14 hours ago
3answers
Atomic Wallet Support Number
However, Atomic wallet is available in desktop and mobile versions which provides convenience. And it is a decentralized wallet where you will get private key for every coin you store in it. It is an open source wallet which means no one can infuse any malicious code into it. https://steemit.com/atomic/@abhijeetcg/atomic-wallet-comparison-with-other-existing-crypto-wallets
4/12/2024 11:27:48 AM • Home • Answered on Apr 12, 2024
3answers
What are the different types of fire extinguishers?
there are 3 types:watercarbon dioxidedry chemicalto learn more about them go here: http://www.ehs.okstate.edu/modules/exting/Types.htm
4/10/2024 10:24:39 AM • Home • Answered on Apr 10, 2024
2answers
How to fix older mobile home suspended ceiling tiles water damaged
replace after fixing the leaking roof
4/5/2024 6:54:09 AM • Home • Answered on Apr 05, 2024
Lost half of my jets on one side of the tub only.I have tried closing the jets that do work half,does not make a difference to the jets not working.Would it be best to empty the tub and start over?
it's likely due to an air lock. Here's what you can do to resolve this issue: Manually Clearing an Airlock: Run the jets on low for about 30 seconds. Then run the jets on high for another 30 seconds. Repeat this process 3 or 4 times. If you hear a gurgling sound and see air bubbling up, continue running your hot tub until it pushes all the air out. If this doesn't work after several attempts, try a different approach. Bleeder Valves or Pump Method: Some spas have bleeder valves that allow you to bleed air out of the lines. First, turn off the spa at the breaker. Access the pump and loosen the valve to allow the air to escape. When the air has bled out (you'll notice it turns from hissing air to a stream of water), close the valve. Run the pump to ensure the jets are now pumping water as expected. Why Are the Jets Not Working on One Side Only?: Many hot tubs have two water pumps. If the jets on only one side of your hot tub stop working, there could be an airlock in only one of the pumps. It could also be a blockage in the jet lines for that side or a problem with the internal mechanism of the jet itself. Can You Use a Spa with an Airlock?: It is not recommended to use a hot tub with an airlock.
4/3/2024 4:33:08 AM • Home • Answered on Apr 03, 2024
Restarting my marcel hour strike quartz clock nrms603.
To restart your Marcel Hour Strike Quartz Clock NRMS603, follow these steps: Stop the Pendulum: Gently stop the pendulum from swinging by holding it still. Remove the Battery: Open the clock case and locate the battery compartment. Remove the existing battery. Wait for a Minute: Leave the clock without a battery for about a minute to allow any residual charge to dissipate. Insert a New Battery: Insert a fresh battery into the compartment, ensuring the correct polarity (usually marked on the battery holder). Start the Pendulum: Gently release the pendulum and let it start swinging. Set the Time: Use the clock's time-setting knob or buttons to adjust the time to the correct hour and minute. Your clock should now be restarted and keeping time accurately
4/3/2024 4:30:05 AM • Home • Answered on Apr 03, 2024
How to replace a sink disposal unit
Look on youtube for videos. There are some key steps and there is electricity involved
3/31/2024 1:17:12 PM • Home • Answered on Mar 31, 2024
How to set the day on the sterling and noble digital wall clock
hold the time button then change accordingly
3/20/2024 12:39:05 AM • Home • Answered on Mar 20, 2024
I have a 30 inch pendulum wall clock. I put 2 AA batteries in, but still won't work. Love the clock, where to take to repair? serial 2,055,787 mfg no 9.
It is from the year 2000, if one believes the Internet search results. These clocks can not be repaired since the hands would almost always be differently attached. Changing parts is also the only option. At best you'll find a clock as donor for both the mechanic part and the hands. Nowadays quartz clocks have seamless motion and therefor no ticking sound. Some are adjusted by radio signals. Please do check if you placed batteries deep enough on the positive side and the contacts not being corroded.
3/16/2024 4:02:39 AM • Home • Answered on Mar 16, 2024
3answers
How to clean mold from a shower
Full strength bleach...let soak 24 hrs
3/14/2024 2:37:25 PM • Home • Answered on Mar 14, 2024
3answers
My sloan flushmate toilet makes
this has already been answered on another site click here http://www.landscapetutorials.com/tips/flushmate-noise.htm
the repair is done by
Fortunately this problem is very easy to cure. Simply follow the instructions below.
  • Remove the ceramic cover from the tank on the back of the toilet.
  • Fill a one-gallon jug with water.
  • Pour the water into the toilet tank. Just pour it over the top of the black plastic Flushmate container. It will run down the sides into the bottom of the ceramic tank. See photo below.
  • Now flush the toilet. The noise should be gone.
if you have any further questions please message me back and please remember to rank how this opinion has helped it allows me to help others in similar situations in the future Thanks again Rick
3/14/2024 9:14:14 AM • Home • Answered on Mar 14, 2024
2answers
I just received my pressure cooker and it keeps giving me an error message E4. why?
Generally, the E4 error code means that the sensor in the pc is faulty and needs to be replaced. Contact the place where you bought it immediately (if it's still under warranty) or contact the manufacturer to ask for a replacement. Good Luck!
3/6/2024 4:37:09 AM • Home • Answered on Mar 06, 2024
F MAUTHE Antique Clock Movement W500 VII. It runs fast. Not the pendulum type.
On the movement by the balance wheel, you will see a small lever with a Plus + and Minus -. Sliding one way or the other changes the accuracy. The better way is to have it cleaned and serviced and have the movement timed electronically. A machine listens to the ticks and you calibrate accordingly. https://www.google.com/search?q=mauthe+w500+vii ..
2/29/2024 6:01:15 AM • Home • Answered on Feb 29, 2024
Where can I find parts for my Strausbourg Manor wall clock please?
I can tell by the sellers of this clock that they are made in China. Due to that, finding parts would be difficult. https://www.google.com/search?q=strausbourg+manor+wall+clock+parts ..
2/29/2024 5:49:39 AM • Home • Answered on Feb 29, 2024
Black and Decker USA Black & Decker FP2500B PowerPro Food Processor Refurbished BLACK Logo
1 questions posted
Top Black and Decker USA Home Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Black and Decker USA Home Expert? Answer questions, earn points and help others
View Most Popular
  • Black and Decker USA Home
Most Popular Question
turn
  • Home
