FixYa.com
Hampton Bay 04383 Calibre Ceiling Fan
All Products > Hampton Bay > Electric Fans
Problems with Hampton Bay 04383 Calibre Ceiling Fan?
Troubleshooting and Support
Solved Problems for Hampton Bay 04383 Calibre Ceiling Fan RSS Feed Post a New Problem
Installing ceiling fan with two switches...
I am installing a Hampton Bay ceiling fan after taking down and old inoperable fan. I have two switches (fan and light)...
2 Solutions
I removed the old fan & light. There...
I removed the old fan & light. There are 3 wires coming out of the ceiling - white, black & red. The wires...
1 Solution
I am trying to install two recessed lights...
I am trying to install two recessed lights (mini) in a series over the sink, one bathroom fan (w/light) and one recessed...
1 Solution
New bulbs in chandelier don't work
Changed light bulbs in chandelier-style ceiling fixture and only two work out of eight.  I bought two packs of GE...
1 Solution
lites overheat
hi we have a landmark plus 42" ceiling fan. from day one the bases get so hot you cant touch them. they also smell...
1 Solution
emerson remote control
Purchased a Emerson Jumbo universal remote control. Have 56" Sony HD Tv, When setting codes, unit went blank and...
1 Solution
Remote control ceiling fan
I have a Hunter ceiling fan that is wired with a three way switch but also operated from a remote. When I turn on the...
1 Solution
View All
Unsolved Support Problems
Unsolved Problems for Hampton Bay 04383 Calibre Ceiling Fan RSS Feed Post a New Problem
cieling fan remote
Need to replace remote that was dropped but unable to locate one. You would think you could look up your fan and order...
Post a Solution
How to wire a remote control ceiling fan,...
I purchased a Hampton Bay "Caswyck" 54" ceiling fan. It comes with a hand held remote control. I do not...
Post a Solution
ceiling fan controller
I have replaced a 3 speed fan controller but I can only get 2 speeds out of it. The switch contains 2 capacitors what...
Post a Solution
install fan
I have a friend and he wants a fan and lighting kit installed. The fan location is the bottom of a stair case. Where he...
Post a Solution
hampton bay fan motor is
hampton bay fan motor is making a loud noise
Post a Solution
Ceiling fan adding a 2nd switch
Have a ceiling fan w/ light, I moved the switch box to a better location and I want to add a 2nd switch to control light...
Post a Solution
problems with a hampton bay fan
installed a new fan, checked for power, once installed, flipped switch to on and fan didn't turn on.
Post a Solution
View All
Tips & Tricks
Post a New Tip
Specifications
Key Features
TypeCeiling
Speeds3 Speeds
FeaturesLight Fitting, Remote Control (Included)
Blades
Number Of Blades3 Blades
Blades Diameter54 in.
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
