When I shut the frig door the freezer door opens slightly. This is causing the freezer to frost...
(More)
When I shut the frig door the freezer door opens slightly. This is causing the freezer to frost over. How can I fix this problem?
The shelves in our freezer fall out of place and thus causes the food to fall down into the next...
(More)
The shelves in our freezer fall out of place and thus causes the food to fall down into the next shelf.
Hi, I've got a GE gss23sgsss side by side with icemaker. I took out the ice bin to fill my cooler...
(More)
Hi, I've got a GE gss23sgsss side by side with icemaker. I took out the ice bin to fill my cooler the other day and since then, no more ice. I've double checked that I put the ice bin back in right and there are no other obvious issues that I know of. I turned off the ice maker and turned it back on. Nothing. The light is on back there. Am I missing something? This thing has worked like a champ up until now. Scratching head....
Frezer seemed to be stuck in Defrost mode, when found ice cube water melted all over floor. After a...
(More)
Frezer seemed to be stuck in Defrost mode, when found ice cube water melted all over floor. After a day went back to working fine. 2 weeks later, ice found on back wall of freezer, enough to impeed fan and make noise. I manually defrosted and removed all ice from blower and coils. 2 weeks later frezer was warm - got food into coolers before it got to 65F. Noticed air from under fridge was 'cold'. Cycle seemed to be stuck in reverse. Set for 24hrs, then swaped out Heater and Thermostat. Hours later still blowing hot air and coils room temperature in freezer. Wife made me buy new fridge after 3 days of trouble shooting. Now stuck trying to figure out if it is control board, (or if there is a defrost timer hidden somewhere), or compressor loop. Any suggestions on narrowing search? First replaced Defrost heater and Thermostat.
Many face the problem of bad odor in refrigerators. Here are few simple tricks to get the problem of bad odor solved:
Keep an open box of baking...
written by techbuster
I had water leaking in to the freezer compartment of my LG french-door refrigerator (LFD25860). It was getting on to food in the main basket and...
written by Tall Peter
I installed a surge protector on the electrical outlet that powers my LG refrigerator as recommended by the repair tech after my first warranty repair...
written by jmorganti
Many people often stress over laying a refrigerator or freezer down in the back of a truck in order to move it. It has happened many, many, times that...
written by MrMark52
Refrigerator not cooling, ice forming on back of side-by-side freezer: Turn off unit. Empty freezer section. Remove freezer back panel (4 screws) to...
written by h_loberg
Try
using an hairdryer or defrosting the unit completely , this often get
rid of blockage caused by frozen lines fixing the problem.
The water...
written by ginko
Have you noticed that when you open the freezer door that you hear a fan running? That's the evaporator fan. When that fan motor goes bad, you'll...
written by SolutionGuy
If you just gotta know how old your appliance is, do this: When you have the full model and serial number (all numbers, all letters) point your web...
written by meyerjr
Defrost your freezer quickly! Steps 1. Turn the freezer off (unplug it). 2. Take out all the food. 3. If required, unscrew the inside-back of the...
by wikihow
If you have a horrible smell in your refrigerator that you can't seem to get rid of, follow these steps to make it history. Even rotten meat has no...
by wikihow
Every so often, a refrigerator needs to be cleaned inside. The shelves have to be washed down from milk spills, and food tossed out if they have...
by wikihow
Fixing a refrigerator is easier then you think. If the light is on, but nothing else works, here's what you can do.
Steps:
1. Check that the knob is...
by wikihow
