20 Most Recent Micrografx Windows Draw Graphics & Print Studio 5 for PC Questions & Answers
Each Micrografx Designer 3.1 *.drw file should hold one page of drawings, and that one page should be at page 1 in the Micrgrafx layout.
Corel Designer Technical Suite X5 has a free 30-day trial period. This program will import a Micrografx Designer *.drw file and let you SAVE AS or EXPORT AS an *.svg file.
Many current drawing programs, e.g., Visio, can import this *.svg file and let you save as a *.vsd file.
But if your *.drw file contained many pages of drawings, your converted file will have many pages of drawings but often in a single large page that you cannot edit. So safer to start out with *.drw files that each contain one page, and that one page should be drawn at page 1 within Micrografx Designer.
I have used the above method to convert very old Micrografx Designer 3.1 *.drw files to Visio *.vsd files. One problem was the Greek letters that were italics in the *.drw file are not italics in the *.vsd file.
Micrografx... | Answered on Oct 09, 2015
Check out this topic: http://windowsdraw.createaforum.com/support/enable-micrografx-windows-draw-6-on-a-64-bit-computer/
there is a link there were you can find support for Micrografx Draw
Micrografx... | Answered on Aug 24, 2014
It is because it is not compatible with win7. But you can run that software in win 7 with xp compatibility mode. For that go to control panel->add remove program then uninstall it from there. Then insert your cd into rom. Then open it and right click on setup.exe then click on property then click on compatibility second tab then select win xp service pack 2 and enable check box of "run as "administrator" then apply and ok. Then run that setup.exe then it will install it in winxp mode in win7 then you can use it. If still not work then you need to buy that software version which is compatible for win7. Let me know if you need further assistance. Thanks for using FixYa.
Micrografx... | Answered on Jun 19, 2013
Hello, I had the same problem. windows draw has been working for years under Windows XP then suddenly impossible. I think there is a conflict with others programs i installed.
I found THE solution after reading many topics on the net :
Install acrobat reader 4 on your system. Then run acrobat reader 4. Last, run Micrografx windows draw 6 while acrobat reader 4 is running on your system too.
Maybe it works with a more recent version of acrobat reader but i didn't try. Maybe this solution works also with windows draw 5 but i didn't try.
Enjoy
Micrografx... | Answered on Feb 28, 2010
uninstall and reinstall the app
Don't Forget to rate the advice!!
http://www.aa1consulting.com
Micrografx... | Answered on Jul 26, 2009
If you have a voltage meter, check that the voltage reads what is printed on the label's "output voltage".
Try a different charger if you have one or borrow from a friend.
It's most likely a bad charger.
Purchase one from Amazon, if it turns out that isn't the problem, then you can just return it.
Computers &... | Answered 53 minutes ago
Hair can grow easily if you use something like aloe vera shampoo. Keep in mind that this will also detox your scalp thoroughly as well.
Aloe Toxin Rid old formula Review exit 5
Computers &... | Answered 1 hour ago
ask your chemist
indications are that it contains codeine which will make it a prescription only **** after February
best go and buy as much as you can while you can
Micrografx Windows Draw Graphics & Print Studio 5 for PC  Logo
24 questions posted
Top Micrografx Computers & Internet Experts
Tom Chichester
Free Robux
Free Robux
Are you a Micrografx Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Micrografx Computers & Internet
Most Popular Question
convert micrografix draw files another
  • Computers & Internet
