My GE refrigerator is getting too cold and freezing items in bottom of refrigerator and toward the...
(More)
My GE refrigerator is getting too cold and freezing items in bottom of refrigerator and toward the back of the refrigerator and freezer not getting very cold. Freezer is on top.
Freezer working good. Frige not cold. The cold setting for frige not lit up. When I turn frige cold...
(More)
Freezer working good. Frige not cold. The cold setting for frige not lit up. When I turn frige cold seting down it does turn off & when turned up you can hear it running . set at cooldest setting & still not very cold.
hi, i defrosted fridge the other day all was fine when i plug it back in a few hour went by and it...
(More)
hi, i defrosted fridge the other day all was fine when i plug it back in a few hour went by and it stopped working now it keep trying to kick on an then off it is an older model but i dont think it needs to be trashed yet?
My GE refrigerator freezes meat and ice cream but not ice cream. The warranty has expired. Has...
(More)
My GE refrigerator freezes meat and ice cream but not ice cream. The warranty has expired. Has anyone else experienced this problem and/or has a solution. Thanks.
The freezer has stopped working intermittantly, everything defrosts and gets mushy then it will...
(More)
The freezer has stopped working intermittantly, everything defrosts and gets mushy then it will start again, make ice and freeze???
refrigerator making wierd noise. they sound like wooing noises that go up and then ''fall'' down as...
(More)
refrigerator making wierd noise. they sound like wooing noises that go up and then ''fall'' down as if what the refrigerator was trying to do failed. the control panel has just been replaced and i need to know what to tell the place i bought it what is wrong.
Many face the problem of bad odor in refrigerators. Here are few simple tricks to get the problem of bad odor solved:
Keep an open box of baking...
written by techbuster
I had water leaking in to the freezer compartment of my LG french-door refrigerator (LFD25860). It was getting on to food in the main basket and...
written by Tall Peter
I installed a surge protector on the electrical outlet that powers my LG refrigerator as recommended by the repair tech after my first warranty repair...
written by jmorganti
Many people often stress over laying a refrigerator or freezer down in the back of a truck in order to move it. It has happened many, many, times that...
written by MrMark52
Refrigerator not cooling, ice forming on back of side-by-side freezer: Turn off unit. Empty freezer section. Remove freezer back panel (4 screws) to...
written by h_loberg
Try
using an hairdryer or defrosting the unit completely , this often get
rid of blockage caused by frozen lines fixing the problem.
The water...
written by ginko
Have you noticed that when you open the freezer door that you hear a fan running? That's the evaporator fan. When that fan motor goes bad, you'll...
written by SolutionGuy
If you just gotta know how old your appliance is, do this: When you have the full model and serial number (all numbers, all letters) point your web...
written by meyerjr
Defrost your freezer quickly! Steps 1. Turn the freezer off (unplug it). 2. Take out all the food. 3. If required, unscrew the inside-back of the...
by wikihow
If you have a horrible smell in your refrigerator that you can't seem to get rid of, follow these steps to make it history. Even rotten meat has no...
by wikihow
Every so often, a refrigerator needs to be cleaned inside. The shelves have to be washed down from milk spills, and food tossed out if they have...
by wikihow
Fixing a refrigerator is easier then you think. If the light is on, but nothing else works, here's what you can do.
Steps:
1. Check that the knob is...
by wikihow
