20 Most Recent
325xi Socket mount. Cigarette lighter / sockets; lateral trunk Questions & Answers
Fuel Injection Pump Plunger 131153-6220
Item Name(EH)#injector bmw 320d e46#
#fit for bosch diesel nozzle price#
#fit for bosch fuel pump nozzle#
#fit for bosch injector nozzel#
#fit for bosch injector nozzle for sale#
#fit for Bosch Injector Nozzles for sale#EH
#fit for bosch injector spray#
China-Lutong is specialized in supplier of diesel fuel injection systems with over 30 years of industrial manufacturing experience. China-Lutong common rail valve provide superior performance and durability and are manufactured to original equipment specifications. You can be confident when you install China-Lutong common rail valves you are receiving a quality diesel injector parts.
Condition : New
Quality : Good
Usage : Industrial
Features : Durable, Smooth Finish
Advantages : Easy to operate
Durability : Long life
nicole(at)china-lutong (dot) net
Wha/tsa/pp:+86133/8690/1375
[email protected]
The probem is that the
take it to a professional suspension shop
could be from failed/seized shockys, springs too strong, suspension mounts failed
At this point I would be looking at one or more shockys as a problem
How to reset anti theft alarm on BMW x5 2002
hello
u will find a lot of wiring diagrams, codes etc and circuit diagrams help books and stuff like this at online places.. like reliable-store
for free
the girl in the chat box can help u instantly... im a frequent buyer there since Im a mechanic so take help from there
2008 328i battery change warning
Make sure you hook a battery charger to the posts under the hood before you change out your battery. Otherwise the car loses all data, has to be flashed, recoded for the new aftermarket battery if that's what you bought and re-registered to the car. Believe me, it's much cheaper just to have the dealer install a new one. This is not all BMW's but some of them require this attention.
Rear view mirror
Have you opened up the door panel to see the wiring connections? Does the mirror appear to have a lighter color ring around the outside? If it does it is probably heated. The best way is to provide the VIN # to the local dealer who can tell you for sure. They should not charge you for this service.
Bmw back lamp
Looking for a replacement bulb? Your local auto parts store can give u the part number of the bulb you need and Walmart should have a book in the aisle for you to look up your vehicle year and model or if they have a tire,lube express they can look up the part number for it.if your looking for the lens then a junkyard, or local auto parts store is the cheapest route.
Sensor keeps beeping
Is it equipped w/? back up alert( beeper)? If so that's why it makes that noise if not then have it checked.
Where is the clutch slave cylinder located on the RC32 mini?
Brake fluid moves from the master cylinder through a tube to the slave cylinder mounted on the transmission so if you are unable to locate the slave cylinder on the transmission follow the hydraulic pressure line from the master cylinder and it will lead you there.
Replace starter on 2004 X3
That is easy if you have a carbridge to work on, so my question is, do you have a carbridge and tools and offcourse your deliver your startmotor for a revised one and change at the same time the poulies and i'll recommened, since bmw has to reset the x3 , just to let it be done by pro's.......not meant negative, but opening the motorhood and somebody with some knowledge ,sees what has to be done .....
