20 Most Recent GE GTS12BBPLCC Top Freezer Refrigerator Questions & Answers
Most/many times this is a clogged up or restricted defrost drain system, but once in a while the drain system has been cleaned and everything appears to be good but you still get ice in the defrost drip tray and such and the drain freezes over. Some manufacture designed kits to help and some home made remedies. http://www.applianceaid.com/defrost_drain_freezes.html
click the link given above
  1. Checking/changing a common light switch
  2. Common frost free fridge parts learn "what" is called "what" before starting your repair
  3. Compressor won't run or it is "clicking' on and off
  4. Cleaning the condenser coils
  5. Can my fridge be moved on it's side?
  6. Defrost drain freezes and then overflows
  7. Freezer door pops open when I shut the fresh food door
  8. GE Arctica repair tips...frost free trouble, freezing food, ect new25.gif
  9. How refrigerators work
  10. How a common defrost cycle works
  11. How to change a common condenser fan motor
  12. How to reverse the refrigerator doors on your refrigerator
  13. Help for storing an appliance
  14. How to change a common Whirlpool evaporator fan motor
  15. How to install or remove common shelf supports
  16. How long can I store food in my frost free refrigerator freezer and how?
  17. I heard a sizzling noise inside my freezer section and it looked like something on fire when I opened the freezer door. What should I do?
  18. I feel heat or warmth around my refrigerator doors...help!
  19. Important Disclaimer
  20. My fridge is running but not cold enough  - with Frost free repair information as well
  21. My refrigerator is leaking water inside the fridge
  22. My fridge is leaking onto the floor
  23. My fridge is freezing things
  24. My fridge makes a bang noise when it shuts off
  25. My Frost free fridge will not run at all
  26. My fridge is making   screeching/squeak noises
  27. My GE SxS fridge door has dropped and/or won't open or close properly
  28. My water dispenser has white flecks in the water...what's up?
  29. Mending a crack in the refrigerator liner
  30. New adaptive defrost information
  31. Ohm meter testing a start capacitor
  32. Odor complaints with your fridge
  33. Replace a door gasket on a refrigerator
  34. Sample wiring diagrams
  35. Stainless Steel Cleaning
  36. Some help for an Amana refrigerator fan motor that will not run
  37. Will my freezer or refrigerator work ok in my garage?
  38. Whirlpool built refrigerator defrost timer installation help
  39. Water line "Y" hose for icemaker broken helps
GE GTS12BBPLCC... | Answered on May 03, 2009
If the unit has an ice maker or water dispensor, etc. there's always a chance a connection is loose or a valve is leaking by. If no other water is hooked up to the refer, then the defrost cycle water that should drain down to the bottom underneath pan is what is likely. You may have to take the inside rear panels off to see if the drain line is plugged up, that would allow water from the defrosting of the coils to drip inside the fridge vice outside like it should.
GE GTS12BBPLCC... | Answered on Aug 14, 2008
The HC95DA700 capacitor is a start capacitor that is used in conjunction with the relay to get the compressor started. Then the relay takes the start cap out of the circuit and the run cap takes over. It could be any of the three components is bad. I usually change all three to be sure. If that doesn't work the compressor is locked up and, in that case, you have to replace the compressor.
GE Refrigerators | Answered on Sep 05, 2019
I had the same problem. The cause is the digital display is not communicating with the motherboard. What had happened in my case is the plug connection between the door's digital display and the motherboard had become unplugged. The wire running from the motherboard runs below the fridge, and connects via plug located along the bottom of the fridge below the freezer door, connecting to the wire running from the display to the bottom of the freezer door. I just reconnected it and that reset the display. Glad for it too, I thought I needed a new $130 motherboard! Hope this helped!
GE Refrigerators | Answered on Aug 29, 2019
look up in to the area of ice flap no screws grab with hands at bottom pull up and out remove 4 screws for ice funnel replace flap
GE Refrigerators | Answered on Aug 28, 2019
Tip
Refrigerator Ice Dispenser Not Working
After about 1 year of usage, ice dispenser panel stops working. Just unplug and plug back after 1 minute (thinking about reboot of PC). Panel starts blinking about 15 hours (be patient!) though the compressor starts working again. Be patient on blinking!
i guess the control board stuck/hung up something on my case. Good luck!
on Aug 26, 2019 | GE Refrigerators
look up on line or if ordering just ask for damper for you make and model but most sale sites have a break down of all parts
GE Refrigerators | Answered on Aug 25, 2019
First check to see if the condenser coils are clean and that the fan is running?
if they are okay
Call an engineer. You have a gas leak and that needs fixing before topping up.
GE Refrigerators | Answered on Aug 01, 2019
GE GTS12BBPLCC Top Freezer Refrigerator Logo
4 questions posted
Top Refrigerators Experts
Brad Goodale
Matt Sicignano
Level 1 Expert
JP Meneide
JP Meneide
View Most Popular
GE Refrigerators
  • GE Refrigerators
Most Popular Question
ge refridgerator
  • Refrigerators
