Hello: I have a GE Built in Oven JKP13. When I had it in Self Cleaning Mode it started beeping and...
(More)
Hello: I have a GE Built in Oven JKP13. When I had it in Self Cleaning Mode it started beeping and showed a F3 code on the control panel. Now it is locked and will not open...How much it for a new Control Panel for this model?
We had a brief power outage while the oven was on and now we have a "F*" error. I cut the...
(More)
We had a brief power outage while the oven was on and now we have a "F*" error. I cut the power for 5 mins as stated in the troubleshooting guide, but oven is not responding.
GE Oven Model: JTP15WA1WW
Replacing ERC part WB27T10065 which has been replaced by ERC part...
(More)
Replacing ERC part WB27T10065 which has been replaced by ERC part WB27T10272...the connection tabs are different and the relays for "bake" and "broil" are different
GE sent the "kit" but not the wiring instructions only the replacement board . Sounds to me like I'm facing the same dilemma as a prior posting......New part does not have the following terminals: Grnd, Plus the "Bake" terminal has been replaced with 2 terminals built in to the relay and the "Broil" relay has been replaced with by a relay with 3 terminals.
On the old part N terminal is connected to OVL2, L1A and L1B are connected together, "Broil" has one contact and "Bake has one contact.I do not know how to connect the new part? Is there a cross connect reference or can you advise me on how to connect the new board using existing oven wiring? kg111@austin.rr.com
GE Model: JTP15WA1WW Replacing ERC part WB27T10065 which has been replaced by part WB27T10272. GE...
(More)
GE Model: JTP15WA1WW Replacing ERC part WB27T10065 which has been replaced by part WB27T10272. GE sent the "kit" but not the wiring instructions ( nice GE...very nice!). SOunds to me lioke I'm facing the same dilemma as a prior posting......New part does not have the following terminals: Grnd, N, L1B or L2B. Plus the "Bake" terminal has been replaced with 2 terminals built in to the relay and the "Broil" terminal has been replaced with 3 terminals. I do not know how to connect the new part? Is there a cross connect reference or where can I go to find out how to connect?
GE Model: JTP15wOA2WW Replacing ERC part WB27T10065 which has been replaced by part WB27T10272. New...
(More)
GE Model: JTP15wOA2WW Replacing ERC part WB27T10065 which has been replaced by part WB27T10272. New part does not have the following terminals: Grnd, N, L1B or L2B. Plus the "Bake" terminal has been replaced with 2 terminals built in to the relay and the "Broil" terminal has been replaced with 3 terminals. I do not know how to connect the new part? Is there a cross connect reference or where can I go to find out how to connect?
My oven is 11 yrs. old and I am receiving the F3, F4 and F5 codes when oven is set to preheat and...
(More)
My oven is 11 yrs. old and I am receiving the F3, F4 and F5 codes when oven is set to preheat and reaches the desired temp. What can I do to resolve this problem?
When we bought the house, we realized that the GE oven, JRP15 was not working correctly. It seems to...
(More)
When we bought the house, we realized that the GE oven, JRP15 was not working correctly. It seems to have a problem in the digital functions. It is set for 350 degrees and will not allow us to program any other temperature. The timer or clock keys also will not function. Is there a part that can be replaced, or do we need to have a repairman do the work?
I JUST CALLED FRIGIDAIRE AND GOT INSTRUCTIONS FOR SELF CLEANING: 1. TAKE OUT THE RACKS UNLESS YOU DON'T MIND THEM TARNISHING 2. TURN THE...
written by NATALIENATAL
Equipment is Whirlpool double oven RBD305PDS14 built-in. After a very stormy summer 2007, I thought a power surge may have zapped the control...
written by babrown
Before you bake something, your oven needs to be heated to the proper temperature. While it takes only a few seconds to turn on your oven, it can take...
by wikihow
Honest, Dependable, Available & Professional!
Appliance Parts Supply! We Ship Nationwide. Our Phones Answered From 7 AM - 9 PM CST Mon - Sat.
Over 30 Years Experience!
972-859-0929 - Call us NOW!
www.accurate-appliance-service.com
