20 Most Recent
Bunn 392 Pourover Coffee Maker With 2 Warmers - Black Questions & Answers
Coffee brewing very weak
possible ways to remedy this problem:problem of weak beveragesolutions:1. Filter Type-BUNN paper filters must be usedfor proper extraction.2. Coffee Grind-A fine or drip grind must be usedfor proper extraction.3. Sprayhead-A six-hole stainless steel spray-head must be used for properextraction.4. Funnel Loading-The BUNN paper filter must be centered in the funnel and the bed of ground leveled by gentle shaking.5. Water Temperature- Place an empty funnel on an emptydispenser beneath the sprayhead. Initiate a brew cycle and check thewater temperature immediately below the sprayhead with a ther-mometer. The reading should not be less than 195F (91C). Adjustthe control thermostat to increase the water temperature. Replace if necessary.
4/24/2013 9:09:19 AM •
Bunn 392...
Answered
on Apr 24, 2013
My sloan flushmate toilet makes
this has already been answered on another site click here
http://www.landscapetutorials.com/tips/flushmate-noise.htm
the repair is done by
Fortunately this problem is very easy to cure. Simply follow the instructions below.
- Remove the ceramic cover from the tank on the back of the toilet.
- Fill a one-gallon jug with water.
- Pour the water into the toilet tank. Just pour it over the top of the black plastic Flushmate container. It will run down the sides into the bottom of the ceramic tank. See photo below.
- Now flush the toilet. The noise should be gone.
if you have any further questions please message me back and please remember to rank how this opinion has helped it allows me to help others in similar situations in the future Thanks again Rick
3/14/2024 9:14:14 AM •
Home
Answered
on Mar 14, 2024
How to fix clock
Do you have the manual with you?
2/9/2024 2:57:33 PM •
Home
Answered
on Feb 09, 2024
